Clone High: Complete Season One ~ Disc 2 - Missing Special Feature Title
TheOneWhoSees
Post by TheOneWhoSees » Sun Aug 16, 2020 12:57 pm
Hello.
I'm using MakeMKV to backup the Clone High DVDs.
However, on the second disc, it doesn't seem to recognise the special features.
I can confirm in the VIDEO_TS folder that the special features are in one title ('VTS_11_1.VOB").
MakeMKV seems to stop at VTS_10_1.VOB (final episode).
Is there any solution to this?
Here's the log.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #11 does not match one in IFO header.
Title #1 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (5 cell(s), 0:22:31)
Title #4 was added (5 cell(s), 0:22:31)
Title #5 was added (5 cell(s), 0:22:31)
Title #6 was added (5 cell(s), 0:22:31)
Title #7 was added (5 cell(s), 0:22:31)
Title #8 was added (5 cell(s), 0:22:31)
Title #9 was added (5 cell(s), 0:22:31)
Title #10 was added (5 cell(s), 0:22:31)
Title #11 was added (5 cell(s), 0:22:31)
Title #12 was added (5 cell(s), 0:22:31)
Title #13 was added (5 cell(s), 0:22:31)
Title #14 was added (5 cell(s), 0:22:31)
Title #15 was added (5 cell(s), 0:22:32)
Title #16 was added (5 cell(s), 0:22:32)
Title #17 was added (5 cell(s), 0:22:32)
Title #18 was added (5 cell(s), 0:22:32)
Title #19 was added (5 cell(s), 0:22:32)
Title #20 was added (5 cell(s), 0:22:32)
Title #21 was added (5 cell(s), 0:22:32)
Title #22 was added (5 cell(s), 0:22:32)
Title #23 was added (5 cell(s), 0:22:31)
Title #24 was added (5 cell(s), 0:22:31)
Title #25 was added (5 cell(s), 0:22:31)
Title #26 was added (5 cell(s), 0:22:31)
Title #27 was added (5 cell(s), 0:22:31)
Title #28 was added (5 cell(s), 0:22:31)
Title #29 was added (5 cell(s), 0:22:31)
Title #30 was added (5 cell(s), 0:22:31)
Title #31 was added (5 cell(s), 0:22:31)
Title #32 was added (5 cell(s), 0:22:31)
Title #33 was added (5 cell(s), 0:22:31)
Title #34 was added (5 cell(s), 0:22:31)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #35 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #35/0/1 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 4-end were skipped due to cell commands (structure protection?)
Title #35/0/2 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 5-end were skipped due to cell commands (structure protection?)
Title #35/0/3 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 6-end were skipped due to cell commands (structure protection?)
Title #35/0/4 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 3 is equal to title 1 and was skipped
Title 3 in VTS 3 is equal to title 1 and was skipped
Title 4 in VTS 3 is equal to title 1 and was skipped
Title 2 in VTS 4 is equal to title 1 and was skipped
Title 3 in VTS 4 is equal to title 1 and was skipped
Title 4 in VTS 4 is equal to title 1 and was skipped
Title 2 in VTS 5 is equal to title 1 and was skipped
Title 3 in VTS 5 is equal to title 1 and was skipped
Title 4 in VTS 5 is equal to title 1 and was skipped
Title 2 in VTS 6 is equal to title 1 and was skipped
Title 3 in VTS 6 is equal to title 1 and was skipped
Title 4 in VTS 6 is equal to title 1 and was skipped
Title 2 in VTS 7 is equal to title 1 and was skipped
Title 3 in VTS 7 is equal to title 1 and was skipped
Title 4 in VTS 7 is equal to title 1 and was skipped
Title 2 in VTS 8 is equal to title 1 and was skipped
Title 3 in VTS 8 is equal to title 1 and was skipped
Title 4 in VTS 8 is equal to title 1 and was skipped
Title 2 in VTS 9 is equal to title 1 and was skipped
Title 3 in VTS 9 is equal to title 1 and was skipped
Title 4 in VTS 9 is equal to title 1 and was skipped
Title 2 in VTS 10 is equal to title 1 and was skipped
Title 3 in VTS 10 is equal to title 1 and was skipped
Title 4 in VTS 10 is equal to title 1 and was skipped
Thanks,
TheOneWhoSees
