PLEASE! Ask before quitting!
mymkv
Post by mymkv » Sun Aug 16, 2020 7:20 am
implement asking-routine closing program while in progress.
always the same, quitting without warning.
Re: PLEASE! Ask before quitting!
Post by Woodstock » Sun Aug 16, 2020 3:14 pm
If MakeMKV is quitting when you haven't told it to, that usually means the operating system shut it down. There should be a pop-up saying that it was being closed, and logs to indicate why.
Post by dcoke22 » Sun Aug 16, 2020 3:20 pm
If you are asking for MakeMKV to ask "Are You Sure?" when one tells it to quit while the app is idle, almost no apps on my Mac do so today. That would be an unusual behavior.
If you are asking for MakeMKV to ask "Are You Sure?" when one tells it to quit while it is ripping a disc… well, it does.
