- 46.0 GB (angle 1) - 00245.mlps - 1,336
- 45.9 GB (angle 2) - 00245.mlps - 1,337
- 46.0 GB (angle 1) - 00246.mlps - 1,336
- 45.9 GB (angle 2) - 00246.mlps - 1,337
Any ideas which one I should rip please?
OK, so I started a decrypted disc backup and then played back 336 and 337. They are just end credits. I have no idea what the difference is since the running times are identical.
Thanks. Always good to learn about these tricks. I was planning to rip all 4 after completing the backup but when I discovered that segments 336 and 337 were both end credits, I just went with 00245.mlps.Woodstock wrote: ↑Mon Aug 31, 2020 5:37 amSince this is not a Lionsgate release, it is more likely that the different angles are a variation on the Disney formula of changing out title and credit segments for different languages.
If I had the space (I usually do) and time, I'd tell MakeMKV to rip all 4, see what languages each has (audio/subtitle), then look at the opening titles on each. Throw away the MKV files that do not match your requirements.
You'd be correct. That is the one I ripped.
