mulucy
#2821 Post by mulucy » Mon Aug 10, 2020 8:30 pm
RESET_9999 wrote: Mon Aug 10, 2020 8:09 pm
mulucy wrote: Mon Aug 10, 2020 7:55 pm
Thank you! The same thing, choose the BL and EL, keep desired sound files with subs, and go either with TS or M2TS? I just hope it will be in profile 7 automatically. BTW, which is better, TS or M2TS for X700?
yep, just remux straight to TS or M2TS, both work fine and yes it will be dual-layer profile 7.
Thank you so much!
sajtipajti
#2822 Post by sajtipajti » Wed Aug 12, 2020 3:54 pm
Ts is smaller.
BUT
Try to remux Apocalypse now Final Cut or Spartacus with tsmuxer and you will get a file which can be played on X700, but X700 shows you that the file is 0:00:00 "long" and you cannot fastforward...
#2823 Post by RESET_9999 » Wed Aug 12, 2020 4:34 pm
sajtipajti wrote: Wed Aug 12, 2020 3:54 pm Ts is smaller.
BUT
Yep, I noticed the same with Lawrence of Arabia so I couldnt skip the first 8min of black screen lol.
sajtipajti
#2824 Post by sajtipajti » Wed Aug 12, 2020 4:54 pm
RESET_9999 wrote: Wed Aug 12, 2020 4:34 pm Yep, I noticed the same with Lawrence of Arabia so I couldnt skip the first 8min of black screen lol.
In case of Spartacus, I found a solution: I splitted it to two parts (in addition I cutted out some blank frames from the middle). Maybe, it will work for you too...
lexyz
#2825 Post by lexyz » Wed Aug 12, 2020 7:13 pm
RESET_9999 shawnc22 SamuriHL
Guys I would like to ask you to do some more pixelhunting :lol:
Here is Valerian test file (FEL) https://gofile.io/d/mpgn5a
Please compare it in HDR/DV mode on Shield. Take a close look on 0:33 mark
I wonder can you spot any difference in gradients around these areas on gun? :roll:
#2826 Post by SamuriHL » Wed Aug 12, 2020 8:32 pm
I can't bring myself to even look at screen shots of that movie much less a video of it. :D I saw it in the theater and hated it. Never have a desire to witness it again in any form. LOL
#2827 Post by RESET_9999 » Wed Aug 12, 2020 11:09 pm
lexyz wrote: Wed Aug 12, 2020 7:13 pm RESET_9999 shawnc22 SamuriHL
No need to compare anything anymore. The Shield just can't play the uhd-bd rips accurately yet.
I've been watching some Netflix on my shield (finally) with the vertex lately. It looks great.
mulucy
#2828 Post by mulucy » Thu Aug 13, 2020 1:16 am
RESET_9999 wrote: Wed Aug 12, 2020 11:09 pm
We are not even 100% sure whether it's discarding the the second layer or not, correct? So many questions about Shield and no answers. Had high hopes! BTW, thank you for your hard work testing and posting videos/screenshots here!
#2829 Post by RESET_9999 » Thu Aug 13, 2020 1:56 am
mulucy wrote: Thu Aug 13, 2020 1:16 am We are not even 100% sure whether it's discarding the the second layer or not, correct?
no way to tell for sure until they fix the color issue.
yusesope
#2830 Post by yusesope » Thu Aug 13, 2020 2:51 pm
Today a pleasant discovery.
In the Spears & Munsil UHD HDR Benchmark disc I found two Dolby Vision versions (FEL and MEL) of the same file.
I had never come across the same file encoded in two different ways.
It could prove to be an important step to reverse the Dolby algorithm and allow FEL -> MEL conversions.
Now smart people have to play "spot the difference" (I personally use HEVCESBrowser for a quick visual analysis).
For those who want to play, here are the files (40 sec cuts):
BL + EL & RPU (FEL)
BL + EL & RPU (MEL)
For those who want to view on the TV the files in question, use as always the tools you have available (mp4muxer, tsMuxer, MakeMKV, my tool, etc...) to create either Single Track and Dual Layer files or "classic" Dual Track and Dual Layer files.
#2831 Post by SamuriHL » Thu Aug 13, 2020 3:50 pm
Ah hell, I never even thought of that aspect. We've been playing with these files for a few weeks now to test the SHIELD. It never even occurred to me that FEL->MEL conversion would be helped by this. But, um, yea!
McZuzlak
#2832 Post by McZuzlak » Thu Aug 13, 2020 8:03 pm
I watched them multiple times with the inbuilt player on my C7 and without a doubt I can clearly see the difference. FEL has more detail and the colors are more punchy.
I won't settle with a MEL only support media player that's for sure.
I'll wait a few more months to see if the Shield color problems are fixed, and accurate playback of FEL content is confirmed but if not I guess it's time to buy a ChinOPPO.
#2833 Post by SamuriHL » Thu Aug 13, 2020 9:11 pm
I'll simply say I don't have a lot of faith that the SHIELD is going to end up having proper FEL support. Which makes it useless for DV playback IMO. We'll see.
#2834 Post by RESET_9999 » Thu Aug 13, 2020 10:02 pm
I have the same feeling... :(
Bresnik17
#2835 Post by Bresnik17 » Sat Aug 15, 2020 6:11 am
yusesope wrote: Thu Aug 13, 2020 2:51 pm Today a pleasant discovery.
BL + EL & RPU (FEL)
BL + EL & RPU (MEL)
I have not yet been able to tell the difference between the MEL and FEL versions of your linked files on my LG internal player when muxed to Profile 7 MP4.
I am not able to properly create a DV TS file for my 2019 Shield from either of the sources that you linked. For some reason, I am not able to mux either set of HEVC files with your tool and finish at "100% 100% 100%", and the subsequent TS files crash in Plex after a few seconds.
