Gandhi
rdgrimes
Gandhi
#1 Post by rdgrimes » Wed Jun 17, 2020 12:58 am
Gandhi UHD not supported. Dumps for disc 1 and for disc 2
MKB20_v68_GANDHI_DISC_2_2CAC.tgz
(3.26 MiB) Downloaded 1073 times
MKB20_v68_GANDHI_DISC_1_94F2.tgz
(3.25 MiB) Downloaded 1228 times
Re: Gandhi
#2 Post by Woodstock » Wed Jun 17, 2020 2:18 am
Are you also emailing these dump files to svq@makemkv.com, so they'll be processed? Posting them on the forum doesn't get them into the system...
jamisonia
Re: Gandhi
#3 Post by jamisonia » Wed Jun 17, 2020 12:46 pm
Are these Columbia Classics BDs AACS 2.1?
Re: Gandhi
#4 Post by SamuriHL » Wed Jun 17, 2020 12:54 pm
No. I've seen then reported elsewhere and they are aacs 2.0.
Re: Gandhi
#5 Post by shawnc22 » Wed Jun 17, 2020 4:05 pm
It's interesting that some of these titles now have to be split onto multiple UHD discs. Do you guys plan on ultimately merging the containers into one?
madfloyd
Re: Gandhi
#6 Post by madfloyd » Wed Jun 17, 2020 7:40 pm
I do!
a_player_so_much_pun
Re: Gandhi
#7 Post by a_player_so_much_pun » Wed Jun 24, 2020 7:37 pm
this one works now! i tried only 'A League...' and 'Ghandi' disv 1 from the Columbia collection and we're in!!
thanks Mike!!!
cipher
Re: Gandhi
#8 Post by cipher » Thu Jun 25, 2020 3:59 pm
Definitely. Just waiting for MKVTOOLNIX to add support for DV so I can merge the two MKV's.
monkeymindboy
Re: Gandhi
#9 Post by monkeymindboy » Wed Aug 12, 2020 12:02 pm
Hello, have you successfully merged Gandhi together into one MKV file? I’ll receive my 4K disc next week and would like to know if there were any issues.
Windows 10 Pro
LG WH16NS40 - UHD Friendly
Asus BW-16D1HT - UHD Friendly
LG WH16NS40 - External Drive - Blu-Ray
HD/DVD - XBOX360 - External Drive
cipher
Re: Gandhi
#10 Post by cipher » Wed Aug 12, 2020 7:10 pm
MakeMKV cannot be used to merge MKV files. You would use MakemKV to create two separate MKV files and then use another tool like MKVTOOLNIX to merge them into a single file. I originally created a merged copy with HDR10+ and have a backup of my original ripped UHD discs for when I'm ready to create a newer merged version with DV.
I heard MKVTOOLNIX recently added support for the newer DV support, but I haven't had a chance to test this out yet.
monkeymindboy
Re: Gandhi
#11 Post by monkeymindboy » Wed Aug 12, 2020 8:48 pm
Thank you for your quick reply. Yes, I have used MKVTOOLNIX before MakeMKV 1.15.2 came out, so I’m familiar with the program. I’m just not sure when you combine all the files, i.e. both video files and both Dolby Atmos tracks how they all flow together. I’ll play around with it next week.
cipher
Re: Gandhi
#12 Post by cipher » Thu Aug 13, 2020 2:45 am
This post should help you when you are ready to do it - https://forums.plex.tv/t/howto-joining- ... gui/113211
monkeymindboy
Re: Gandhi
#13 Post by monkeymindboy » Fri Aug 14, 2020 6:58 pm
Awesome! Thank you.
