Post by SamuriHL »
I'll simply say I don't have a lot of faith that the SHIELD is going to end up having proper FEL support. Which makes it useless for DV playback IMO. We'll see.
I have the same feeling... :(
Bresnik17
Post by Bresnik17 »
yusesope wrote: Thu Aug 13, 2020 2:51 pm Today a pleasant discovery.
In the Spears & Munsil UHD HDR Benchmark disc I found two Dolby Vision versions (FEL and MEL) of the same file.
I had never come across the same file encoded in two different ways.
It could prove to be an important step to reverse the Dolby algorithm and allow FEL -> MEL conversions.
Now smart people have to play "spot the difference" (I personally use HEVCESBrowser for a quick visual analysis).
For those who want to play, here are the files (40 sec cuts):
BL + EL & RPU (FEL)
BL + EL & RPU (MEL)
For those who want to view on the TV the files in question, use as always the tools you have available (mp4muxer, tsMuxer, MakeMKV, my tool, etc...) to create either Single Track and Dual Layer files or "classic" Dual Track and Dual Layer files.
I have not yet been able to tell the difference between the MEL and FEL versions of your linked files on my LG internal player when muxed to Profile 7 MP4.
I am not able to properly create a DV TS file for my 2019 Shield from either of the sources that you linked. For some reason, I am not able to mux either set of HEVC files with your tool and finish at "100% 100% 100%", and the subsequent TS files crash in Plex after a few seconds.
BringerChaos
Post by BringerChaos »
Regarding making FEL and MEL Dolby vision files..
For FEL titles do I need to use mode 1 (BL+EL+RPU) of yusecopes tool in order to retain all necessary Dolby vision data?
For MEL titles are both mode 1 (BL+EL+RPU) and mode 2 (BL+RPU) suitable to retain all necessary Dolby vision data?
If the above isn't correct, whats the logic between choosing one over the other?
Also any info regarding which Dolby vision profiles would be suitable for my setup would be appreciated please.
Firestick 4K and Sony X9500G
Thanks in advance!
MastaG
Post by MastaG »
BringerChaos wrote: Sat Aug 15, 2020 12:36 pm Regarding making FEL and MEL Dolby vision files..
Thanks in advance!
I guess if it's a MEL title you could also use mode 2 (BL+RPU) because the enhanced layer contains metadata only.
I could be wrong though.
BringerChaos
MastaG wrote: Sat Aug 15, 2020 4:15 pm
Thanks in advance!
Thanks, that's my understanding also.
My current workflow is:
Mode 1(BL+EL+RPU) and tsmuxer 04.06 for FEL titles
Mode 2(BL+RPU) and tsmuxer 05.06 for MEL titles
If there are any flaws in the above, someone please do let me know. I'm still not sure on the profiles if I'm being honest.
yusesope
Post by yusesope »
Bresnik17 wrote: Sat Aug 15, 2020 6:11 am I have not yet been able to tell the difference between the MEL and FEL versions of your linked files on my LG internal player when muxed to Profile 7 MP4.
In this case (and only in this case), don't worry about the counters: my tool is designed to handle huge files (and not test files of a few MB). v0.0.4a returns a correct file and I am sure that mp4muxer can generate playable files on TV (both ST-DL and DT-DL). But all this work is useless: the "differences" I referred to in my previous post are to be found on a binary level, digging between 0s and 1s, and not looking at the TV screen.
MastaG wrote: Sat Aug 15, 2020 4:15 pm I guess if it's a MEL title you could also use mode 2 (BL+RPU) because the enhanced layer contains metadata only.
BringerChaos wrote: Mon Aug 17, 2020 5:28 pm Mode 1(BL+EL+RPU) and tsmuxer 04.06 for FEL titles
No, this type of use is wrong.
"mode 1" (default) should ALWAYS be used (regardless of FEL and MEL).
However, not all platforms can handle movies generated from the HEVC raw stream in "mode 1".
Devices, such as the Apple TV 4K, which can only play Dolby Vision profile 5 and 8 files must resort to "mode 2".
The files produced in "mode 2" are technically wrong (the topic has been debated in this thread many times, use the "search" box).
The use of this mode should be reserved for those devices that are unable to handle files produced in mode 1.
I don't encourage using "mode 2" (I just wanted to offer a free feature compared to DVDFab).
"mode 2" should only be used in "extrema ratio"
PS:
Any of your future questions has already been answered.
Use the "search" box and some key words (or search for my username, shawnc22, RESET_9999, SamuriHL, ragico, etc..)
RayDawGGG
Post by RayDawGGG »
I'm grateful and thankful for everyone who has worked on this project! I have a lot of DV remuxes(obtained from the wild). My playback devices are the 2019 Shield Pro and the LG CX. Every DV profile(4-8) I muxed using yusesope tool and tsmuxer play flawlessly in DV with Atmos/DTS:X on the 2019 Shield Pro via Plex. On MXPlayer Pro, only Profile 4 plays in DV, Profile 5 plays in HDR only(both with Dolby Digital only). Profile 6,7,8 play with so much contrast that it makes the movie unviewable. These DV muxes play the same way as MXPlayer Pro does on the CX internal player and the CX Plex app. I muxed them all in -mode 1.. then I read that was wrong, so i muxed them again according to this:
Profile 4: BL+EL+RPU, SDR compatible -mode 1
Profile 5: BL+RPU, (Unspecified colorspace = IPT) -mode 2
Profile 6: BL+EL+RPU, HDR10 compatible -mode 1
Profile 7: track 1 BL non-DV, track 2 EL+RPU HDR10 compatible -mode 1
Profile 8: BL+RPU, HDR10 or HLG or SDR compatible -mode 2
Now that I read yusesope stating that -mode 2 is only for Apple TV 4K, I'm going to mux them again back in -mode 1 before I post screenshots. Whether I muxed them in -mode 1 or -mode 2 they all still played back the same way on all devices.. Trash in MXPlayer Pro and The CX internal player,.. Flawlessly on the Shield via Plex. Out of all the profiles, Profile 8 looks the best IMO on the Shield. The colors popped more and the picture was more detailed in Dolby Vision versus HDR. There is definitely a visual difference between the two on the Shield. We have to take all this with a grain of salt. We don't have 12bit panels to utilize Dolby Vision's implementation and color gamut to it's fullest extent. I'm pleased with everyone's efforts and am very ecstatic about finally being able to play my remuxed DV MKV's. I was worried that I'd have to re rip them from the UHD's that I don't have.. Fortunately, they didn't lose or corrupt their metadata by being stored in the MKV container.
kazuma
Post by kazuma »
Why is my M9702 showing 1920x1080 resolution with a mp4 profile 7 file?
RayDawGGG
Post by RayDawGGG »
kazuma wrote: Fri Aug 21, 2020 5:21 pm Why is my M9702 showing 1920x1080 resolution with a mp4 profile 7 file?
Without us seeing the Mediainfo for your file.. we won't be able to discern all the variables for your dilemma.
RayDawGGG
Post by RayDawGGG »
Mike, Yusescope and all the other phenomenal people who worked on this are geniuses!
My conjecture after reading all 191 pages of this forum is that all of our TV's discard/ignore the 12bit EL layer when playing UHD's. We don't have 12bit panels so the EL layer is unnecessary for now. Even though our UHD's are in Profile 7, our TV's still play them as Profile 8. Why?, because they are not 12bit panels and cannot process the EL layer.
After reviewing this again;
and Yusescope stating Profile 5 is for Apple TV4K only, along with all the profile compatibility issues people are having. It occurred to me that Profile 5[BL+RPU] is what our TV's streaming service, our streaming boxes and Apple TV4K use to play DV. So no matter what profile we mux in(except 8), they are all played back as Profile 5 BL+RPU for compatibility with our TV's. Apple TV4K isn't a UHD player, so it has no need for the profiles that contain the EL layer(Our TV's can't use it anyway). Profile 8 is used for playback of UHD's from our TV, so Apple TV4K doesn't have a need for that profile either. Our UHD players decodes the Profile 7 BL+EL+RPU dual layers of our UHD's and sends it to our TV's via HDMI. Our TV's DV decoder then combines the BL+EL+RPU layers into Profile 8 BL+RPU single layer. So even if our mp4,ts or m2ts files have BL+EL+RPU in them, our TV's will still discard/ignore the EL layer and play them as Profile 5[BL+RPU] unless we mux to Profile 8. Profile 5 is the standard for streaming because of the 12bit panel EL layer issue and bandwidth allocation... just a hypothesis.
mulucy
Post by mulucy »
RayDawGGG wrote: Sat Aug 22, 2020 12:42 am Mike, Yusescope and all the other phenomenal people who worked on this are geniuses!
You got 10-bit and 12-bit correct. But downsampling from 12-bit to 10-bit will always be better than native 10-bit ( kinda like downscaling from 4k to 1080p as opposed to native 1080p content ).
Profile 5 and 8 are good, but mode -2 with yusecope tool is not producing right colors. But it's better than standard HDR, more like with 5 and 8 profiles you are getting HDR10+, both are unspecified color spaces though.
The best way to watch is through Profile 7, ideally speaking. But profile 4 and 6 are also the same, the colors should be the same ( Profile 7 is dual-layer and dual track, but profile 4 and 6 are dual-layer single track ).
BringerChaos
yusesope wrote: Tue Aug 18, 2020 11:33 am
PS:
Thank you for clarifying this Yusecope. I'd previously been searching this thread with the strings FEL & MEL, which were too short to return a result(my mistake for not searching mode 1 & 2), so I resorted to asking via the thread in order to educate myself to create proper and semi permanent files for my library.
You previously included the Firestick 4k along with the Apple TV 4K as devices that required DV Profile 5 (and mode 2) in one of your earlier posts, is this still the case or is the Firestick 4k now able to play Profile 4 and mode 1 produced files?
Thanks again
RayDawGGG
Post by RayDawGGG »
mulucy wrote: Sat Aug 22, 2020 1:13 am
RayDawGGG wrote: Sat Aug 22, 2020 12:42 am Mike, Yusesope and all the other phenomenal people who worked on this are geniuses!
and Yusesope stating Profile 5 is for Apple TV4K only, along with all the profile compatibility issues people are having. It occurred to me that Profile 5[BL+RPU] is what our TV's streaming service, our streaming boxes and Apple TV4K use to play DV. So no matter what profile we mux in(except 8), they are all played back as Profile 5 BL+RPU for compatibility with our TV's. Apple TV4K isn't a UHD player, so it has no need for the profiles that contain the EL layer(Our TV's can't use it anyway). Profile 8 is used for playback of UHD's from our TV, so Apple TV4K doesn't have a need for that profile either. Our UHD players decodes the Profile 7 BL+EL+RPU dual layers of our UHD's and sends it to our TV's via HDMI. Our TV's DV decoder then combines the BL+EL+RPU layers into Profile 8 BL+RPU single layer. So even if our mp4,ts or m2ts files have BL+EL+RPU in them, our TV's will still discard/ignore the EL layer and play them as Profile 5[BL+RPU] unless we mux to Profile 8. Profile 5 is the standard for streaming because of the 12bit panel EL layer issue and bandwidth allocation... just a hypothesis.
Thank you for responding!
Okay, So the EL is downsampled not discarded/ignored. I don't have the 7.06 tsMuxer. I only have the 4.06(fix), 5.06(fix) 6.06, and 8.06(fix). When using Yusesope's tool in mode -1 or mode -2 there isn't a visual difference between BL+EL+RPU and BL+RPU in any of the profiles i use ie.. Profile 4 BL+EL+RPU and Profile 4 BL+RPU. I fully understand that Profile 4 is BL+EL+RPU SDR and Profile 8 is BL+RPU HDR10. I only made all the profiles in mode -2 or mode -1 for testing purposes. I don't have the 7.06 tsMuxer, so I muxed a Profile 7 dual layer single track mp4. All the profiles play very well and in the same colors in Plex on the Shield 2019. The only color difference on my end is when I play any of the profiles(4 -8) through USB on the LG CX. The colors look dull in Profile 4. I assume that's because my UHD remuxes are in HDR and Profile 4 is for SDR? Maybe it's the CX? I don't have any of the color issues or stuttering issues that people write of with any of my DV muxes. Regardless of the profile/mode I use in the Plex Shield app they all look great! Profiles 7 and 8 also play well in MXPlayer Pro. I'm just thankful that I can watch my DV remuxes. MP4Muxer does not support Atmos, so I use Profile 8 with Atmos/DTS:X in m2ts... I wonder now if I'm supposed to use the newest nightly tsMuxer? It makes dual layer single track Profile 6. I assume my confusion comes from UHD's being dual layer dual track(Profile 7) and MP4muxer, tsMuxer making Profile (4-8)dual layer single tracks. My question is why does tsMuxer make Profile 6 instead of Profile 7 dual layer single tracks like MP4muxer does if Profile 7 is the best way to watch with players that support them?
Boss21
Post by Boss21 »
please can anyone share ts muxer 05.06 fix , 06.06 fix and 07.06 to download. Iwant to create dv profile 5 to be play on Apple TV through infuse pro.
thanks
