Wind River (2017) - Audio Issue
AngryVirginian
#1 Post by AngryVirginian » Thu Aug 13, 2020 9:04 pm
I am having an audio issue with Wind River (2017) blu-ray ripped with 1.15.2. There is no audio at all during the first two minutes of the movie played through Plex. This happens in both DTS-HD MA and the underlying DTS tracks. The disc played fine through the Xbox One. Below is the log.
AV sync issue in stream 1 at 0:00:15.056 with duration of 105.071s : encountered overlapping frame, audio skew is +105.071s
AV sync issue in stream 1 at 0:00:29.237 : audio changes from 16bps to 24bps, you won't be able to convert this track to any other format later, please use a conversion profile with audio transcoding
AV sync issue in stream 1 at 0:00:29.237 with duration of 1008.5ms : encountered overlapping frame, audio skew is +90.89s
AV sync issue in stream 2 at 0:00:15.056 with duration of 105.071s : encountered overlapping frame, audio skew is +105.071s
AV sync issue in stream 2 at 0:00:29.237 with duration of 1008.5ms : encountered overlapping frame, audio skew is +90.89s
AV sync issue in stream 1,2 at 0:02:00.128 with duration of 106.08s : 9945 frame(s) dropped to reduce audio skew to -0.208ms
Seems like a big chunk of the fames got dropped. Any hint on how to fix this is appreciated. Thanks.
lmm5247
Re: Wind River (2017) - Audio Issue
#2 Post by lmm5247 » Sat Nov 22, 2025 4:00 pm
AngryVirginian wrote: Thu Aug 13, 2020 9:04 pm I am having an audio issue with Wind River (2017) blu-ray ripped with 1.15.2. There is no audio at all during the first two minutes of the movie played through Plex. This happens in both DTS-HD MA and the underlying DTS tracks. The disc played fine through the Xbox One. Below is the log.
Hey, what did you end up doing with this? I'm having the same issue, first two minutes with no audio on this stand-alone disc when ripped from MakeMKV.
Saving 1 titles into directory /home/XXXXX/Videos/Wind River
AV sync issue in stream 4 at 0:00:00 : Forced subtitles track #4 turned out to be empty and was removed from output file
1 titles saved
I am going to try this copy, but it's all 3 films on one disc, so they're each significantly smaller than the stand-alone copy.
