AV synchronization issues were found in file
Bulldog81973
#1 Post by Bulldog81973 » Thu Aug 13, 2020 5:19 pm
On August 12th I did what everyone does apply latest and greatest Windows updates:
These are the two updates:
August 11, 2020—KB4566782 (OS Build 19041.450) & August 11, 2020-KB4569745 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 2004
Now every time I use MakeMKV on one of my BluRay's I get this AV synchronization issues were found in file and the resultant file keeps skipping time while playing back.
I tried uninstalling the 2 new updates to revert back but as soon as I do and reboot, it re-installs the updates upon the startup.
Any idea as to why this is doing this?
I am using Window 10 (latest version) and MakeMKV version 1.15.2 and I bought it and registered it (screenshot attached)
Help please
Bulldog81973
Re: AV synchronization issues were found in file
#2 Post by Bulldog81973 » Fri Aug 14, 2020 11:16 am
is anyone else having this issue?
#3 Post by d00zah » Fri Aug 14, 2020 3:01 pm
Bulldog81973 wrote: Fri Aug 14, 2020 11:16 am is anyone else having this issue?
search.php?keywords=AV+synchronization+ ... were+found
Bulldog81973
#4 Post by Bulldog81973 » Sun Aug 16, 2020 2:01 am
@ d00zah - Thank you, so yes others are having the issue...is there a solution? I appreciate you at least answering my post, however it did not help me find a solution.
BTW just so everyone knows, I bought a new BluRay/DVD +/- RW drive and I am having the same issue.
Anyone from the software development team able to help us out with this issue?
preserve
#5 Post by preserve » Sun Aug 16, 2020 4:34 am
What is the disc you’re having trouble with?
What specific AV sync errors are you seeing? Can you post your log file as an attachment?
What playback software are you using?
Using: ASUS BW-16D1HT 3.00
Bulldog81973
#6 Post by Bulldog81973 » Sun Aug 16, 2020 7:00 pm
Split 2006, Hellboy 2019, Hobbs & Shaw (2019) Hotel Artemis 2018, Alien 1979. All Bluray's.
I use Plex for media playback.
I just tried something and played the file back on the computer using VLC and didn't have the skipping issues.
I also used the Plex software from my firestick/firetv and didn't have the issue, but when I run the file using the plex login through t he web browser, it skips like crazy through out the movie...? very interesting.
I also tried just writing the disk straight to the hard drive then copying over to the NAS and there is no difference.
I just tried to do Hellboy 2019 again straight to the NAS and get the following errors:
Saving 1 titles into directory M:/Movies/Hellboy (2019)
AV synchronization issues were found in file 'M:/Movies/Hellboy (2019)/Hellboy-FPL_MainFeature_t03.mkv' (title #4)
AV sync issue in stream 3 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 4 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 5 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 3,4,5 at 0:00:00 with duration of 9ms : encountered overlapping frame, audio skew is +9ms
DEBUG: Code 0 at {jh$~Hd ?TZ>P#@H:213137045
AV sync issue in stream 2 at 0:04:31.729 with duration of 14.208ms : encountered overlapping frame, audio skew is +14.208ms
AV sync issue in stream 3,4,5 at 0:04:31.703 with duration of 31.997ms : encountered overlapping frame, audio skew is +40.997ms
AV sync issue in stream 3,4,5 at 0:04:58.743 with duration of 32ms : encountered overlapping frame, audio skew is +72.997ms
AV sync issue in stream 3,4,5 at 0:04:58.816 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8.997ms
AV sync issue in stream 2 at 0:04:58.756 with duration of 13ms : encountered overlapping frame, audio skew is +27.208ms
