1.15.2 fails at startup with - undefined symbol DriveIoQueryAdd
petea
#1 Post by petea » Thu Aug 13, 2020 3:50 pm
I've been building makemkv for quite some time now, but as of 1.15.2, I get the error:
/usr/bin/makemkvcon: symbol lookup error: /usr/bin/makemkvcon: undefined symbol: DriveIoQueryAdd
This causes a Fatal error and the program ends.
Also, where can I download the previous version, since I deleted it before I noticed the issue.
Thanks.
Re: 1.15.2 fails at startup with - undefined symbol DriveIoQueryAdd
#3 Post by mike admin » Fri Aug 14, 2020 9:33 am
petea wrote: Thu Aug 13, 2020 3:50 pm I've been building makemkv for quite some time now, but as of 1.15.2, I get the error:
This means that you are using an old version of OSS package, not the one from 1.15.2
grad_devil
#4 Post by grad_devil » Thu Aug 20, 2020 3:05 pm
I'm actually experiencing the same issue, building/installing both oss and bin from the 1.15.2 tar.gz downloads.
The error
appears, the MakeMKV GUI hangs, and then ends with a "Fatal error occurred, program will now exit"
I get this when I inspect makemkvcon:
$ makemkvcon -r info
MSG:1005,0,1,"MakeMKV v1.15.2 linux(x64-release) started","%1 started","MakeMKV v1.15.2 linux(x64-release)"
makemkvcon: symbol lookup error: makemkvcon: undefined symbol: DriveIoQueryAdd
I'm no expert - any ideas on what's causing this or how to fix it?
I'm running:
Fedora 32 (64-bit)
5.7.14-200 kernel
--grad_devil
grad_devil
#5 Post by grad_devil » Fri Aug 21, 2020 5:00 pm
Here's an update:
I solved this by manually removing the following files from /usr/lib and /usr/lib64
  • libdriveio.so.0
  • libmakemkv.so.1
  • libmmbd.so.0
Re-downloaded/built and now everything works ok. Just thought I would post it here in case it helps someone else!
ThaeWizGwar
#6 Post by ThaeWizGwar » Fri Aug 06, 2021 7:10 am
This just fixed my issue. I'm very thankful that you posted this update to your initial issue. I created an account just to thank you for posting this fix, and to let others know that this could help them as well. THANK YOU.
#7 Post by Woodstock » Fri Aug 06, 2021 12:53 pm
Why would you be installing such an old version at this point?
ThaeWizGwar
#8 Post by ThaeWizGwar » Tue Aug 10, 2021 8:03 am
I'm running v1.16.4 (beta) and ran into this exact issue after being forced to upgrade from an older version.
