1.15.2 fails at startup with - undefined symbol DriveIoQueryAdd
petea
Post by petea »
I've been building makemkv for quite some time now, but as of 1.15.2, I get the error:
/usr/bin/makemkvcon: symbol lookup error: /usr/bin/makemkvcon: undefined symbol: DriveIoQueryAdd
This causes a Fatal error and the program ends.
Also, where can I download the previous version, since I deleted it before I noticed the issue.
Thanks.
Re: 1.15.2 fails at startup with - undefined symbol DriveIoQueryAdd
Post by mike admin »
petea wrote:
Thu Aug 13, 2020 3:50 pm
This means that you are using an old version of OSS package, not the one from 1.15.2
grad_devil
Post by grad_devil »
I'm actually experiencing the same issue, building/installing both oss and bin from the 1.15.2 tar.gz downloads.
The error
appears, the MakeMKV GUI hangs, and then ends with a "Fatal error occurred, program will now exit"
I get this when I inspect makemkvcon:
$ makemkvcon -r info
MSG:1005,0,1,"MakeMKV v1.15.2 linux(x64-release) started","%1 started","MakeMKV v1.15.2 linux(x64-release)"
makemkvcon: symbol lookup error: makemkvcon: undefined symbol: DriveIoQueryAdd
I'm no expert - any ideas on what's causing this or how to fix it?
I'm running:
Fedora 32 (64-bit)
5.7.14-200 kernel
--grad_devil
grad_devil
Here's an update:
I solved this by manually removing the following files from /usr/lib and /usr/lib64
  • libdriveio.so.0
  • libmakemkv.so.1
  • libmmbd.so.0
Re-downloaded/built and now everything works ok. Just thought I would post it here in case it helps someone else!
ThaeWizGwar
Post by ThaeWizGwar »
This just fixed my issue. I'm very thankful that you posted this update to your initial issue. I created an account just to thank you for posting this fix, and to let others know that this could help them as well. THANK YOU.
Why would you be installing such an old version at this point?
ThaeWizGwar
I'm running v1.16.4 (beta) and ran into this exact issue after being forced to upgrade from an older version.
