Gandhi
Gandhi
Gandhi UHD not supported. Dumps for disc 1 and for disc 2
- MKB20_v68_GANDHI_DISC_2_2CAC.tgz
- (3.26 MiB) Downloaded 1387 times
- MKB20_v68_GANDHI_DISC_1_94F2.tgz
- (3.25 MiB) Downloaded 1536 times
Re: Gandhi
Are you also emailing these dump files to svq@makemkv.com, so they'll be processed? Posting them on the forum doesn't get them into the system...
Re: Gandhi
Are these Columbia Classics BDs AACS 2.1?
Re: Gandhi
No. I've seen then reported elsewhere and they are aacs 2.0.
Re: Gandhi
It's interesting that some of these titles now have to be split onto multiple UHD discs. Do you guys plan on ultimately merging the containers into one?
a_player_so_much_pun
Re: Gandhi
this one works now! i tried only 'A League...' and 'Ghandi' disv 1 from the Columbia collection and we're in!!
thanks Mike!!!
thanks Mike!!!
monkeymindboy
Re: Gandhi
Hello, have you successfully merged Gandhi together into one MKV file? I’ll receive my 4K disc next week and would like to know if there were any issues.
Windows 10 Pro
LG WH16NS40 - UHD Friendly
Asus BW-16D1HT - UHD Friendly
LG WH16NS40 - External Drive - Blu-Ray
HD/DVD - XBOX360 - External Drive
Re: Gandhi
MakeMKV cannot be used to merge MKV files. You would use MakemKV to create two separate MKV files and then use another tool like MKVTOOLNIX to merge them into a single file. I originally created a merged copy with HDR10+ and have a backup of my original ripped UHD discs for when I'm ready to create a newer merged version with DV.monkeymindboy wrote: ↑Wed Aug 12, 2020 12:02 pmHello, have you successfully merged Gandhi together into one MKV file? I’ll receive my 4K disc next week and would like to know if there were any issues.
I heard MKVTOOLNIX recently added support for the newer DV support, but I haven't had a chance to test this out yet.
monkeymindboy
Re: Gandhi
Thank you for your quick reply. Yes, I have used MKVTOOLNIX before MakeMKV 1.15.2 came out, so I’m familiar with the program. I’m just not sure when you combine all the files, i.e. both video files and both Dolby Atmos tracks how they all flow together. I’ll play around with it next week.cipher wrote: ↑Wed Aug 12, 2020 7:10 pmMakeMKV cannot be used to merge MKV files. You would use MakemKV to create two separate MKV files and then use another tool like MKVTOOLNIX to merge them into a single file. I originally created a merged copy with HDR10+ and have a backup of my original ripped UHD discs for when I'm ready to create a newer merged version with DV.monkeymindboy wrote: ↑Wed Aug 12, 2020 12:02 pmHello, have you successfully merged Gandhi together into one MKV file? I’ll receive my 4K disc next week and would like to know if there were any issues.
Re: Gandhi
This post should help you when you are ready to do it - https://forums.plex.tv/t/howto-joining- ... gui/113211monkeymindboy wrote: ↑Wed Aug 12, 2020 8:48 pmThank you for your quick reply. Yes, I have used MKVTOOLNIX before MakeMKV 1.15.2 came out, so I’m familiar with the program. I’m just not sure when you combine all the files, i.e. both video files and both Dolby Atmos tracks how they all flow together. I’ll play around with it next week.
monkeymindboy
Re: Gandhi
Awesome! Thank you.cipher wrote: ↑Thu Aug 13, 2020 2:45 amThis post should help you when you are ready to do it - https://forums.plex.tv/t/howto-joining- ... gui/113211monkeymindboy wrote: ↑Wed Aug 12, 2020 8:48 pmThank you for your quick reply. Yes, I have used MKVTOOLNIX before MakeMKV 1.15.2 came out, so I’m familiar with the program. I’m just not sure when you combine all the files, i.e. both video files and both Dolby Atmos tracks how they all flow together. I’ll play around with it next week.
