LG CX with Bluray rips with Dolby vision. is it possible to get DV to work?
Teletha
#1 Post by Teletha » Wed Aug 12, 2020 2:20 pm
Hello, I was sure that the tv supported dual layer but when i play my ripped blu-ray disc of my movie 1917 in the built-in video player on the tv it set's the hdr to normal HDR10. It doesn't seem to detect Dolby vision is it not getting the right metadata?
im playing the .m2ts file directly from the decrypted BD stream folder.
Codec Bitrate Description----- ------- -----------MPEG-H HEVC Video 70109 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10+ v1 Profile B / BT.2020* MPEG-H HEVC Video 7272 kbps (9.40%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
MediaInfo dump:
File Name :00294.m2tsFormat : BDAVFormat/Info : Blu-ray VideoFile size : 73.7 GiBDuration : 1 h 59 minOverall bit rate mode : VariableOverall bit rate : 88.7 Mb/sMaximum Overall bit rate : 109 Mb/s
Video #1ID : 4113 (0x1011)Menu ID : 1 (0x1)Format : HEVCFormat/Info : High Efficiency Video CodingFormat profile : Main 10@L5.1@HighHDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatibleCodec ID : 36Duration : 1 h 58 minWidth : 3 840 pixelsHeight : 2 160 pixelsDisplay aspect ratio : 16:9Frame rate : 23.976 (24000/1001) FPSColor space : YUVChroma subsampling : 4:2:0 (Type 2)Bit depth : 10 bitsColor range : LimitedColor primaries : BT.2020Transfer characteristics : PQMatrix coefficients : BT.2020 non-constantMastering display color primaries : Display P3Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2Maximum Content Light Level : 1000 cd/m2Maximum Frame-Average Light Level : 168 cd/m2
Video #2ID : 4117 (0x1015)Menu ID : 1 (0x1)Format : HEVCFormat/Info : High Efficiency Video CodingFormat profile : Main 10@L5.1@HighHDR format : SMPTE ST 2086, HDR10 compatibleCodec ID : 36Duration : 1 h 58 minWidth : 1 920 pixelsHeight : 1 080 pixelsDisplay aspect ratio : 16:9Frame rate : 23.976 (24000/1001) FPSColor space : YUVChroma subsampling : 4:2:0 (Type 2)Bit depth : 10 bitsColor range : LimitedColor primaries : BT.2020Transfer characteristics : PQMatrix coefficients : BT.2020 non-constantMastering display color primaries : Display P3Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Audio #1ID : 4352 (0x1100)Menu ID : 1 (0x1)Format : AC-3 MLP FBA 16-chFormat/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentationCommercial name : Dolby TrueHD with Dolby AtmosMuxing mode : Stream extensionCodec ID : 131Duration : 1 h 58 minBit rate mode : VariableBit rate : 448 kb/sMaximum bit rate : 7 158 kb/sChannel(s) : 8 channelsChannel layout : L R C LFE Ls Rs Lb RbSampling rate : 48.0 kHzFrame rate : 31.250 FPS (1536 SPF)Compression mode : LossyStream size : 381 MiB (1%)Service kind : Complete MainNumber of dynamic objects : 11Bed channel count : 1 channelBed channel configuration : LFE
