How are you checking this? Mediainfo? That has not been updated yet, see also post above from SamuriHL.Boss21 wrote: ↑Tue Aug 11, 2020 3:47 pmPlease can you help what I am doing wrong.
I followed new method for saving Dv parameters while ripping the movie
I ripped the Dolby vision movie using new update the movie file saved is showing HDR10+.
I used the same to file with TVs muxer nightly update to get the Ts file
The ts file I got still don’t have any Dolby vision parameters.
The original disc contains Dolby vision metadata
Please can someone help what I am doing wrong while making the movie file.
Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
If you're making TS files, mediainfo should show DV info. My guess is that the wrong version of tsmuxer is being used. Look at the earlier pages of this thread for a version labeled "04.06" fix.
I am using media info to look for information in the file. I am using tsmuxer 2.6.12. What should I used for checking the file ?
Just to confirm something, this DV included mkv files can only be played back on NVIDIA shield as of right now? I tried using my Oppo 203 and they only played in HDR10, is there anyway to play this on oppo except the whole backup, and which other hardware is able to do this?
I have updated my original post
Do not have a real Oppo, but the clone. That clone should be equal and indeed to get DV you need to play the full backup. The DV mkvs are not recognized as DV and it is more than unlikely that this will be changed. Only other file based DV option is using the 04.06 tsmuxer and remux to m2ts. But that has its minus, like no chapters as example.xmenw wrote: ↑Tue Aug 11, 2020 8:20 pmJust to confirm something, this DV included mkv files can only be played back on NVIDIA shield as of right now? I tried using my Oppo 203 and they only played in HDR10, is there anyway to play this on oppo except the whole backup, and which other hardware is able to do this?
With the APK from yuse, I can play the DV mkvs on the shield and works like a charm.
Hopefully exoplayer will be updated any time soon, so that Emby or other apps can use the DV version.
mrhollywood
Sorry if I'm misreading, but it's hard to keep up with this. Are you saying profile 7 dv directly ripped with MakeMKV is working on the sheild?
Agreed. It's kind of weird that 4 months have passed since v20.03 was released and now a new version is released without this support. Unless a lot of effort is required to add this DV logic, it may have made more sense to release the new version once the new DV code was implemented.Balthazar2k4 wrote: ↑Tue Aug 11, 2020 3:34 pmDisappointed to see the new version of MediaInfo still doesn't identify DV in MKV containers. The wait continues...
Lets hope we're now not waiting a couple of months for the DV version.
GREAT! THX!
Yes works wonderfully. The profile doesn't seem to really matter if I got that right.mrhollywood wrote: ↑Wed Aug 12, 2020 6:03 pmSorry if I'm misreading, but it's hard to keep up with this. Are you saying profile 7 dv directly ripped with MakeMKV is working on the sheild?
I think MAKEMKV does not produce profile 7 mkv. Unless I misunderstood it combines the 2 layers and retains the DV data.mrhollywood wrote: ↑Wed Aug 12, 2020 6:03 pmSorry if I'm misreading, but it's hard to keep up with this. Are you saying profile 7 dv directly ripped with MakeMKV is working on the sheild?
These files do work on a shield with the apk from yusesope.
MAKEMKV mentions dvhe.07.06 BL+EL+RPU FEL or MEL during the creation of the DV mkv.
when using this apk as external player for kodi, im guesssing you cant use zoomfunctions anymore?yusesope wrote: ↑Mon Aug 03, 2020 4:44 pmHi testers!
Today it was really too hot...that's why I spent a few hours coding with the aim of implementing chapters support (for mkv files only).
The code is very "basic" (to say the least) and I hope it works properly!
Furthermore, if you open the app directly, you can play the test files that mike has made available.
HERE you can find the new apk.
Let me know!
It depends on the functionality of the external player used. All Kodi functionality ceases to play a role in playback, as you're using a different player.userr wrote: ↑Thu Aug 13, 2020 5:07 pmwhen using this apk as external player for kodi, im guesssing you cant use zoomfunctions anymore?yusesope wrote: ↑Mon Aug 03, 2020 4:44 pmHi testers!
Let me know!
As it relates to the custom ExoPlayer, no there is no zoom option in the version, as it is largely a proof of concept to show that DV content from MKVs can be played.
