Twilight 0 titles saved, 23 failed
newtonuk
Post by newtonuk »
Hi there, I'm having difficulty ripping Twilight PAL to either MKV or a complete disc back up.
MakeMKV v1.6.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/rob/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HC10" opened in OS access mode.
Optical drive "BD-RE PIONEER BD-ROM BDC-202 1.07" opened in OS access mode.
File 00031.mpls was added as title #0
File 00029.m2ts was added as title #1
File 00028.m2ts was added as title #2
File 00027.m2ts was added as title #3
Title #00038.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #4
File 00025.m2ts was added as title #5
File 00024.m2ts was added as title #6
Title #00023.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00034.m2ts was added as title #7
Title #00022.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00014.m2ts was added as title #8
File 00013.m2ts was added as title #9
File 00012.m2ts was added as title #10
Title #00011.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.m2ts was added as title #11
File 00009.m2ts was added as title #12
File 00008.m2ts was added as title #13
File 00007.m2ts was added as title #14
File 00006.m2ts was added as title #15
Title #00042.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #16
Title #00039.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #17
File 00003.m2ts was added as title #18
Title #00044.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #19
Title #00043.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.m2ts was added as title #20
Title #00041.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.m2ts was added as title #21
Title #00040.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00030.m2ts was added as title #22
Saving 23 titles into directory /Users/rob/Desktop
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '7461531648'
DEBUG: Code 0 at C+jf2).u{99EgQ6L:213137091
DEBUG: Code 1073741830 at rrB}@)bp]+_xS-|'9[:29395839
DEBUG: Code 1073741830 at rrB}@)bp]+_xS-|'9[:121261727
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '7461531648'
DEBUG: Code 0 at k&b&FoRqqa9v@NU.sLO:121263958
DEBUG: Code 0 at =y`YC@(UD_=li,5t}km::29394298
DEBUG: Code 0 at KN3sHn&ygq,[PiiD"T%I:121261681
DEBUG: Code 0 at =y`YC@(UD_=li,5t}km::29394183
DEBUG: Code 3643326 at =y`YC@(UD_=li,5t}km::29393309
DEBUG: Code 0 at ^GR>u(ewS%2yJq6}V)P'2:29397449
Failed to save title 0 to file /Users/rob/Desktop/title00.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00029.m2ts' at offset '0'
DEBUG: Code 0 at zdvl>]Ub]8<4D]OecD:29393286
Failed to save title 1 to file /Users/rob/Desktop/title01.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00028.m2ts' at offset '0'
Failed to save title 2 to file /Users/rob/Desktop/title02.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00027.m2ts' at offset '0'
Failed to save title 3 to file /Users/rob/Desktop/title03.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00026.m2ts' at offset '0'
Failed to save title 4 to file /Users/rob/Desktop/title04.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00025.m2ts' at offset '0'
Failed to save title 5 to file /Users/rob/Desktop/title05.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00024.m2ts' at offset '0'
Failed to save title 6 to file /Users/rob/Desktop/title06.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00034.m2ts' at offset '0'
Failed to save title 7 to file /Users/rob/Desktop/title07.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '0'
Failed to save title 8 to file /Users/rob/Desktop/title08.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00013.m2ts' at offset '0'
Failed to save title 9 to file /Users/rob/Desktop/title09.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00012.m2ts' at offset '0'
Failed to save title 10 to file /Users/rob/Desktop/title10.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '0'
Failed to save title 11 to file /Users/rob/Desktop/title11.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '0'
Failed to save title 12 to file /Users/rob/Desktop/title12.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '0'
Failed to save title 13 to file /Users/rob/Desktop/title13.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '0'
Failed to save title 14 to file /Users/rob/Desktop/title14.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '0'
Failed to save title 15 to file /Users/rob/Desktop/title15.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '0'
Failed to save title 16 to file /Users/rob/Desktop/title16.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'
Failed to save title 17 to file /Users/rob/Desktop/title17.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
Failed to save title 18 to file /Users/rob/Desktop/title18.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Failed to save title 19 to file /Users/rob/Desktop/title19.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Failed to save title 20 to file /Users/rob/Desktop/title20.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
Failed to save title 21 to file /Users/rob/Desktop/title21.mkv
Error 'Posix error - Device not configured' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '0'
Failed to save title 22 to file /Users/rob/Desktop/title22.mkv
I don't know if this is too much information or not enough.
Re: Twilight 0 titles saved, 23 failed
Post by mike admin »
This looks like physically damaged disc. To confirm, please try to make a full disc backup with MakeMKV or copy files in finder.
