I am using a BU40N drive running 1.03 firmware and on makemkv 1.15.1 and 1.15.2, the extended trilogy blu ray will rip and the video appears fine, but the audio is very distorted. I tried ripping it with only english audio and subtitles, and again excluding nothing. Both attempts had distorted audio on both versions of makemkv.
Is there anything I can do to fix this?
Lord of the Rings horrible audio rip
preserve
Re: Lord of the Rings horrible audio rip
If you didn't see any errors, MakeMKV will have copied the audio exactly as it is on the disc.
If you have authentic Blu-rays and they play fine in a normal Blu-ray player, then the issue may be with your playback software or settings.
I had no issues with the extended trilogy and have never had distorted audio on any rip.
Using: ASUS BW-16D1HT 3.00
CT3B0
What are you using for the media playback? - When I recently copied the LOTR trilogy extended edition, I too noticed the audio wasn't right when playing on VLC media player. All the character dialogue was very quiet while background music and other sounds were loud.
I managed to find a fix on VLC by going to the top bar menu: Audio -> Stereo Mode then changing it from Original to Stereo.
Just checking there, whenever I open the files in VLC the audio is on Original by default.
