lexyz
Post by lexyz » Sun Aug 09, 2020 6:58 am
LG profile 4 BL+EL+RPU demo is really odd on my setup
Some kind of artefacts on letters edges in DV version. SDR is clean
https://screenshotcomparison.com/compar ... /picture:0
Ugly orange sky in DV
https://screenshotcomparison.com/compar ... /picture:1
mulucy
Post by mulucy » Mon Aug 10, 2020 3:39 am
Which version of TSMuxer I should be using to create a profile 7 TS or M2TS containers with my Sony X700? Is profile 7 best way to play DV UHD disk videos with X700?
McZuzlak
Post by McZuzlak » Mon Aug 10, 2020 9:22 am
Is it planned for feature makemkv revisions to create specific dv profiles without third party apps ?
The new Zidoo will support dv but profile 7 is excluded. Its confirmed that they are working on the SDK, and developing Dolby Vision support for MKV containers regarding profiles 4,5,8 & 9.
flashback8
Post by flashback8 » Mon Aug 10, 2020 3:43 pm
I doubt MakeMKV will support conversion to other DV profiles. The policy has always been to just copy the data over into a new container, not to translate the data into other forms beyond what's absolutely necessary to get the data into MKV form. A more likely approach, IMO, would be for players to support on-the-fly conversion into other profiles. I suppose MakeMKV could potentially write a program that allows for conversion of MKVs to other profiles. I wouldn't count on it but you never know.
Of course, I could be wrong about all of this. :)
mulucy
Post by mulucy » Mon Aug 10, 2020 6:03 pm
anyone?
mulucy
Post by mulucy » Mon Aug 10, 2020 6:12 pm
RESET_9999 wrote:
Thu Mar 19, 2020 10:24 pm
Alldu wrote:
Thu Mar 19, 2020 9:44 pm
Hy guys, anybody know what's the best way to embed sub/idx or ass subtitles into the DV mp4? I play my DV files via X700 and for some reason it can't read ass subs properly and sub/idx at all, if I put them in the same folder as DV mp4. Thanks!
You don't have to use the MP4 container anymore with the x700. You can remux your UHD bluray disc directly to .TS or .M2TS using this tsMuxer:
https://drive.google.com/file/d/1IWYPO4 ... sp=sharing
DV, Atmos and subs will work.
it appears the file has been removed. Do you still have a copy of Tsmuxer for the Profile 7? Thank you in advance!
mulucy
Post by mulucy » Mon Aug 10, 2020 7:55 pm
RESET_9999 wrote:
Mon Aug 10, 2020 7:45 pm
@mulucy
latest build should work.
https://bintray.com/justdan96/tsMuxer/t ... htly#files
Thank you! The same thing, choose the BL and EL, keep desired sound files with subs, and go either with TS or M2TS? I just hope it will be in profile 7 automatically. BTW, which is better, TS or M2TS for X700?
Post by RESET_9999 » Mon Aug 10, 2020 8:09 pm
yep, just remux straight to TS or M2TS, both work fine and yes it will be dual-layer profile 7.
mulucy
Post by mulucy » Mon Aug 10, 2020 8:30 pm
Thank you so much!
sajtipajti
Post by sajtipajti » Wed Aug 12, 2020 3:54 pm
Ts is smaller.
BUT
Try to remux Apocalypse now Final Cut or Spartacus with tsmuxer and you will get a file which can be played on X700, but X700 shows you that the file is 0:00:00 "long" and you cannot fastforward...
Post by RESET_9999 » Wed Aug 12, 2020 4:34 pm
Ts is smaller.
BUT
Yep, I noticed the same with Lawrence of Arabia so I couldnt skip the first 8min of black screen lol.
sajtipajti
Post by sajtipajti » Wed Aug 12, 2020 4:54 pm
In case of Spartacus, I found a solution: I splitted it to two parts (in addition I cutted out some blank frames from the middle). Maybe, it will work for you too...
lexyz
Post by lexyz » Wed Aug 12, 2020 7:13 pm
RESET_9999 shawnc22 SamuriHL
Guys I would like to ask you to do some more pixelhunting :lol:
Here is Valerian test file (FEL) https://gofile.io/d/mpgn5a
Please compare it in HDR/DV mode on Shield. Take a close look on 0:33 mark
I wonder can you spot any difference in gradients around these areas on gun? :roll:
Post by SamuriHL » Wed Aug 12, 2020 8:32 pm
I can't bring myself to even look at screen shots of that movie much less a video of it. :D I saw it in the theater and hated it. Never have a desire to witness it again in any form. LOL
