Which version of TSMuxer I should be using to create a profile 7 TS or M2TS containers with my Sony X700? Is profile 7 best way to play DV UHD disk videos with X700?
Is it planned for feature makemkv revisions to create specific dv profiles without third party apps ?
The new Zidoo will support dv but profile 7 is excluded. Its confirmed that they are working on the SDK, and developing Dolby Vision support for MKV containers regarding profiles 4,5,8 & 9.
flashback8
I doubt MakeMKV will support conversion to other DV profiles. The policy has always been to just copy the data over into a new container, not to translate the data into other forms beyond what's absolutely necessary to get the data into MKV form. A more likely approach, IMO, would be for players to support on-the-fly conversion into other profiles. I suppose MakeMKV could potentially write a program that allows for conversion of MKVs to other profiles. I wouldn't count on it but you never know.
Of course, I could be wrong about all of this. :)
it appears the file has been removed. Do you still have a copy of Tsmuxer for the Profile 7? Thank you in advance!RESET_9999 wrote: ↑Thu Mar 19, 2020 10:24 pmYou don't have to use the MP4 container anymore with the x700. You can remux your UHD bluray disc directly to .TS or .M2TS using this tsMuxer:
https://drive.google.com/file/d/1IWYPO4 ... sp=sharing
DV, Atmos and subs will work.
Thank you! The same thing, choose the BL and EL, keep desired sound files with subs, and go either with TS or M2TS? I just hope it will be in profile 7 automatically. BTW, which is better, TS or M2TS for X700?RESET_9999 wrote: ↑Mon Aug 10, 2020 7:45 pm@mulucy
latest build should work.
https://bintray.com/justdan96/tsMuxer/t ... htly#files
yep, just remux straight to TS or M2TS, both work fine and yes it will be dual-layer profile 7.
Thank you so much!RESET_9999 wrote: ↑Mon Aug 10, 2020 8:09 pmyep, just remux straight to TS or M2TS, both work fine and yes it will be dual-layer profile 7.
sajtipajti
Ts is smaller.RESET_9999 wrote: ↑Mon Aug 10, 2020 8:09 pmyep, just remux straight to TS or M2TS, both work fine and yes it will be dual-layer profile 7.
BUT
Try to remux Apocalypse now Final Cut or Spartacus with tsmuxer and you will get a file which can be played on X700, but X700 shows you that the file is 0:00:00 "long" and you cannot fastforward...
Yep, I noticed the same with Lawrence of Arabia so I couldnt skip the first 8min of black screen lol.sajtipajti wrote: ↑Wed Aug 12, 2020 3:54 pmTs is smaller.
BUT
sajtipajti
In case of Spartacus, I found a solution: I splitted it to two parts (in addition I cutted out some blank frames from the middle). Maybe, it will work for you too...RESET_9999 wrote: ↑Wed Aug 12, 2020 4:34 pmYep, I noticed the same with Lawrence of Arabia so I couldnt skip the first 8min of black screen lol.
RESET_9999 shawnc22 SamuriHL
Guys I would like to ask you to do some more pixelhunting
Here is Valerian test file (FEL) https://gofile.io/d/mpgn5a
Please compare it in HDR/DV mode on Shield. Take a close look on 0:33 mark
I wonder can you spot any difference in gradients around these areas on gun?
I can't bring myself to even look at screen shots of that movie much less a video of it.
I saw it in the theater and hated it. Never have a desire to witness it again in any form. LOL
No need to compare anything anymore. The Shield just can't play the uhd-bd rips accurately yet.lexyz wrote: ↑Wed Aug 12, 2020 7:13 pmRESET_9999 shawnc22 SamuriHL
Guys I would like to ask you to do some more pixelhunting![]()
I wonder can you spot any difference in gradients around these areas on gun?![]()
I've been watching some Netflix on my shield (finally) with the vertex lately. It looks great.
