Dolby Vision and 1.15.1
SOLARIS
Re: Dolby Vision and 1.15.1
Post by SOLARIS »
Got it working thank you for anyone who wants the config file it is attached place it in your directory and it will use the exoplayer as default just make sure you restart kodi
\\SHIELD\internal\Android\data\org.xbmc.kodi\files\.kodi\userdata
playercorefactory.xml
(926 Bytes) Downloaded 2782 times
Bob1321
Post by Bob1321 »
Its not working on my Firestick 4K :(
Someone was able to make it work?
quietvoid
Post by quietvoid »
Bob1321 wrote: Thu Aug 06, 2020 7:53 pm Its not working on my Firestick 4K :(
Yes, everything except profile 4 and 7 FEL works for me.
Ulyank
Post by Ulyank »
Same; I can’t get exoplayer to play any file on the Firestick
Dinst
Post by Dinst »
Is anyone else having an issue with playback failing at precisely 15:36? It does it with multiple files so definitely not a corrupt file.
oldirtydog
Post by oldirtydog »
Guys,i thinking to buy(preorder Zidoo Z9X).In this case wil i have to enjoy a DV on mkv -Zidoo has confirmed that they are working on the SDK, and developing Dolby Vision support for MKV containers regarding profiles 4,5,8 & 9. Good stuff! or i use the old methods-ts muxer>yoroscope to single layer and eac3togui to add the atmos truehd and make the .TS file ?
Post by shawnc22 »
oldirtydog wrote: Sat Aug 08, 2020 4:30 am Guys,i thinking to buy(preorder Zidoo Z9X).In this case wil i have to enjoy a DV on mkv -Zidoo has confirmed that they are working on the SDK, and developing Dolby Vision support for MKV containers regarding profiles 4,5,8 & 9. Good stuff! or i use the old methods-ts muxer>yoroscope to single layer and eac3togui to add the atmos truehd and make the .TS file ?
not sure how you expect anyone here to answer that when the product hasn't been publicly released yet
DaMacFunkin
Post by DaMacFunkin »
Mmm I’d be worried about this quote:
*Built-in VS10 engine could process Dolby Vision very well. All files could be mapped to similar color of Dolby Vision, image quality improves a lot.
Similar color doesn’t sound good to me, it’s the reason I’m currently not using the shield.
DaMacFunkin
Further more it doesn’t currently support Profile 7, which is what our rips are, correct?
oldirtydog
DaMacFunkin wrote: Sat Aug 08, 2020 6:49 am
DOLBY VISION VS10 Dolby Vision VS10 supports not just Dolby Vision, but also HDR10+ / HDR10 with Dolby's VS10 HDR processing engine for improved dynamic range. Dolby Vision VS10 on Zidoo delivers the best HDR image quality in all instances. See FAQ question for details on Dolby Vision Profile support.
By selecting this option, HDR content is processed by the VS10 engine to properly match your High Dynamic Range (including Dolby Vision capable ones) or SDR display. There is also a note in the menu description stating:
“This option support Dolby Vision standard mode and is recommended when playing HDR or Dolby Vision content on non-HDR devices.”
2. Dolby Vision Low Latency (LLDV, YUV422,12Bit)
This option works on Dolby Vision displays allowing SDR content to be processed and then converted to Dolby Vision. In simple words, SDR – > HDR Dolby Vision. The end result is impressive, considering the total lack of any high dynamic range information, but we would rather have the processing power reserved for better upscaling. Still, no complaints whatsoever.
Lkr721993
Post by Lkr721993 »
SOLARIS wrote: Thu Aug 06, 2020 6:07 pm Got it working thank you for anyone who wants the config file it is attached place it in your directory and it will use the exoplayer as default just make sure you restart kodi
Thanks, that worked perfectly after installing exoplayer build linked a few pages back
Trying to load the demo content in the app itself fails, but I can navigate to a SMB share in Kodi, and launch Gladiator which I just re-ripped with 1.15.2, and I am getting both Dolby Vision and DTS X.
So for my feedback... I am using an nvidia shield 2019 tube for this - when kodi launches the video in exoplayer, it runs at 60fps. I open the mini menu on the shield to do frame-rate matching, but the display refreshes and exoplayer says it cannot play the file.
Gotta say this is an exciting time!
xmenw
Post by xmenw »
I have tried to read through the last 10 pages or so, to confirm, if I get a Nvidia Shield I can playback in lossless quality DV + Atmos, is that a correct assumption? I have NFS & Samba Shares. And as I understand the rips can’t be played back via Oppo 203 as of right now?
I usually do full disc unencrypted backups, how would I got about ripping these for losseless DV+base layer and Atmos?
Thanks for all the good work!
kweenie
Post by kweenie »
Indeed, it sounds a bit vague and reading what it does or “could” do to me it seems similar to what the Apple TV4K does. When you set The APTV4K to DV it will output everything as DV, regardless the input. Nothing really new. The difference is as I understand, if there is regular HDR or DV in the file, it will not be processed in their engine, but displayed as it should. Personally I am always a little concerned when “engines” and whatnot are presented where the original signal goes into a blackbox and nobody knows what has been done. Real or fake DV, etc...
Think it still is to early to jump from mediaplayer to mediaplayer. They all want to be the first to announce support for DV mkv and get that slice of the market.
oldirtydog
This is from the chinesse review of Zidoo Z9X
kcxserver
Post by kcxserver »
Kodi 19.x "Matrix" - Alpha 1
Android:
Static HDR10 support for all source types (if supported by the device)
Dynamic Dolby Vision HDR support for streaming services (if supported by the device)
https://kodi.tv/article/kodi-19x-matrix-alpha-1
