Hi, I have read an article that my Drive is UHD friendly, I've got a few movies in 4K but when I try it it doesn't detect it, I am currently using windows 8.1 as OS so, can you guide me with this issue I think even detecting it will be enough rather than the playback and I have enclosed the features of the PC below.
Details:
LG Bluray drive WH16NS40
RAM:8GB DDR3
PROCESSOR: I-5 3330@3.00GHZ
OS: Windows 8.1
Issue regarding detection and playback of 4k in supported bluray player
Re: Issue regarding detection and playback of 4k in supported bluray player
Open MakeMKV and select that drive. It should spit out all the drive info in a window. Paste that here.
There are 2 versions of that hardware. One supports UHD, one DOES NOT. There are physical labels on the drive that show what version you have, but what does MakeMKV report?
Example:
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.03
Serial number: xxxxxxxxxxxx
Firmware date: 2117-11-21 16:53
Drive platform: MT1959 (IMPORTANT, if 'MT1939', hardware is too old)
Harware support: Yes
Firmware support: No
Firmware version: 1.03
What SamuriHL said...
Example:
OS device name: F:
Revision: 1.03
Thank you for your reply buddies here what makemkv said
OS device name: F:
Revision: 1.02
Firmware date: 2114-05-07 10:26
Drive platform: MT1939
Firmware version: 1.02
BD raw metadata read: Partial
OS device name: F:
Revision: 1.02
Basically, the drive is a year too old to have UHD capability, but it can (and does) use LibreDrive to enhance what it CAN do.
someone please guide me I am a newbie so I don't know much about it so please guide me to do it if possible if not I am happy with 2k bluray's i don't want to brick my drive because I don't have money to buy a new one
you dont need to do anything your drive reads all the discs it ever will
