Pioneer BDR-S12UHT
TheAlphaant
Pioneer BDR-S12UHT
Anyone know if the Pioneer BDR-S12UHT is going to get any LibreDrive functionality at any point?
Blackened2687
Re: Pioneer BDR-S12UHT
AFAIK, Pioneer drives don't (yet?) support this feature.
By the way, I'm working on a Pioneer flashing tool (currently called "DVRTool") and want to support these S12/212 series, too. Please contact me, if you have already bought this drive.
And, if by any chance the program tells you something like "saved file FW_xxxxx.tgz, please send it" - then please do as it says
TheAlphaant
Sorry guys, not long after i bought the drive unfortunately it stopped working.
While i had the chance i ended up getting an asus drive as a replacement, sorry I couldn't be of help
Blackened2687
If somebody else will get this drive, please contact me, I need to dump some binary data from this drive to add its support to a Pioneer drive flasher I'm working on. Thanks in advance!
Pasquizle
I have this drive and I may be able to helpBlackened2687 wrote: Mon Nov 04, 2019 1:52 pm If somebody else will get this drive, please contact me, I need to dump some binary data from this drive to add its support to a Pioneer drive flasher I'm working on. Thanks in advance!
Blackened2687, I sent my dump to mike a few months ago. I didn't realize until now that you were after a dump for this model too. Anyway, here you go.Blackened2687 wrote: Mon Nov 04, 2019 1:52 pm If somebody else will get this drive, please contact me, I need to dump some binary data from this drive to add its support to a Pioneer drive flasher I'm working on. Thanks in advance!
albertrossy
I have Pioneer BDR-XD05TB
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: OLDL005607WL
Firmware date: 2017-06-22
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8232
Firmware version: ID34
Any chance Ill be able to get LibreDrive support fingers crossed!
OS device name: J:
Revision: 3.10
