Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
It's more noticeable in some content than others.
@ Pmaw10 , nop, I noticed the difference right away. But I do really care(probably too much lol) about color accuracy.
The shield came out on Oct 28th, noticed the saturation on Nov 7th.
viewtopic.php?f=12&t=18602&p=80752#p80727
But it's probably more obvious with uhd-bd rip than streaming app.
Ouch, the comments I read must have been relating to ethernet playback. I still would prefer to use the Shield because of having files in mkv format (subtitles, space etc), of course colour reproduction has to be correct before anything else.baker99 wrote: ↑Tue Aug 04, 2020 3:41 pmYes usb is perfect, just frustrating the ethernet port sucksRESET_9999 wrote: ↑Tue Aug 04, 2020 10:50 amno problems at all when played via the USB port. Even the 60fps 4k DV FEL Atmos Gemini Man works.
The good news from Nvidia is:
Team is still working to hunt down what's going on.
The slightly worrying news is:
If the problem isn't fixed the "gamble" wouldn't have cost me too much as used Shields seem to hold most of their value. After selling the Shield I would probably buy a Sony x700 as temporary fix until a new device is released that solves all problems.We still don't really know if SHIELD is correct or not.
I've just unboxed my Shield, once I set everything up I'm going to compare the Doctor Sleep scene with my TVs internal player.
edit: Well that didn't last long. I was going through the set up screen and the Shield automatically started to download an update. It got towards the end and just after I pushed my AVR back a little the Shield turned off and now won't turn back on lol. My Odroid N2 which is the only other thing connected to my AVR turns on and off fine. When I removed the HDMI cable that's connected to my Shield from my AVR I felt a little buzz on my finger.
Netflix Marvel content makes it insanely noticeable. The way they seem to shoot things seems to bring it out more than other sources. Most other times, I don't notice it. I did some tweaks on the HDFury Vertex 2 to alleviate the issue, but it'd be nice if nVidia fixed it.
I find it really noticeable on some titles, Saving Private Ryan just looks ‘off’ other titles the sky looks blown also, if you are not suceptable to colour shift then it will look great, I think most people that it bothers have another source to compare it with, once you have seen it done correctly it becomes unwatchable.
Yup it's been updated.
Is there any central place to see what kind of Dolby Vision profile that is used on the single UHDs? I tried to look at the blu-ray.com list of DV films, but they do not track that information.
https://forum.blu-ray.com/showthread.php?t=276448
I just want to find out whether the Shield limitation on certain DV profiles is a big issue, and hence buy a separate UHD disc player for these discs
they’re all profile 7evilmatcher wrote: ↑Wed Aug 05, 2020 1:46 pmIs there any central place to see what kind of Dolby Vision profile that is used on the single UHDs? I tried to look at the blu-ray.com list of DV films, but they do not track that information.
Thanks - and since MKV 1.15.2 converts the profile 7 to a profile 4 I won't have any problems - right?shawnc22 wrote: ↑Wed Aug 05, 2020 3:08 pmthey’re all profile 7evilmatcher wrote: ↑Wed Aug 05, 2020 1:46 pmIs there any central place to see what kind of Dolby Vision profile that is used on the single UHDs? I tried to look at the blu-ray.com list of DV films, but they do not track that information.
MakeMKV does no such thing, but the Shield can play the profile 7 files just fine. Whether or not it's playing them accurately is a whole separate discussion, however.evilmatcher wrote: ↑Wed Aug 05, 2020 3:49 pmThanks - and since MKV 1.15.2 converts the profile 7 to a profile 4 I won't have any problems - right?shawnc22 wrote: ↑Wed Aug 05, 2020 3:08 pmthey’re all profile 7evilmatcher wrote: ↑Wed Aug 05, 2020 1:46 pmIs there any central place to see what kind of Dolby Vision profile that is used on the single UHDs? I tried to look at the blu-ray.com list of DV films, but they do not track that information.
Thanks for the clarificationshawnc22 wrote: ↑Wed Aug 05, 2020 3:52 pmMakeMKV does no such thing, but the Shield can play the profile 7 files just fine. Whether or not it's playing them accurately is a whole separate discussion, however.evilmatcher wrote: ↑Wed Aug 05, 2020 3:49 pmThanks - and since MKV 1.15.2 converts the profile 7 to a profile 4 I won't have any problems - right?
Many thanks for the app!yusesope wrote: ↑Mon Aug 03, 2020 4:44 pmHi testers!
Today it was really too hot...that's why I spent a few hours coding with the aim of implementing chapters support (for mkv files only).
The code is very "basic" (to say the least ) and I hope it works properly!
Furthermore, if you open the app directly, you can play the test files that mike has made available.
HERE you can find the new apk.
Let me know!
Can you implement the autoframerate function from this? https://github.com/yuliskov/SmartYouTub ... oframerate
Ive installed Exoplayer by copying the file to my nas then installing on the shield through file explorer.
How do I get videos to play through exoplayer i cant seem to play any through kodi to get it to launch the app neither can I change the add on settings to change the player any insight will be a great help.
It is not a priority (you can easily solve with THIS app). Unfortunately I only have a 1080p 60Hz device: it would be difficult for me to debug the code.NiCE77 wrote: ↑Thu Aug 06, 2020 11:09 amCan you implement the autoframerate function from this? https://github.com/yuliskov/SmartYouTub ... oframerate
Start reading from page 62 and you will find all the answers.
