On-the-fly decryption software enabled
Librewhat
Post by Librewhat » Tue Aug 04, 2020 10:32 pm
Been using MKV for a while and never had this pop up before, does anyone know what this is or why it popped up?
"It appears that you have on-the-fly decryption software enabled. MakeMKV should process discs with the most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable such software and restart the application.
Do you want to continue anyway (errors may follow)?"
I don't have any other software, 3rd party, trying to decrypt. Been using MKV the same each time but this time I get this message. There has been a recent upgrade for MKV, I wonder if that has something to do with this?
Re: On-the-fly decryption software enabled
Post by Billycar11 » Tue Aug 04, 2020 11:20 pm
Maybe the disc is a backup disc and no longer encrypted?
thetoad
Post by thetoad » Fri Aug 07, 2020 8:22 pm
are you working on an ISO or a physical disc?
Librewhat
Post by Librewhat » Sat Aug 08, 2020 3:27 pm
Physical disc.
Ezatoka
Post by Ezatoka » Sun Aug 09, 2020 12:16 am
Is it a DVD? I think the detection goes off, when there is something in brackets in the title manifest of the DVD
Librewhat
Post by Librewhat » Sun Aug 09, 2020 2:30 am
It was a DVD. I have since copied another and this time no message like this. It must have had something to do with that particular disk.
Enam101
Post by Enam101 » Wed Jan 26, 2022 6:23 am
Im also experiencing exactly the same problem.
My source is soft Bluray files. Anyone, please advise what software suppose to check and disable as 'On the Fly Decrypt' software.
