LG WH14NS40 firmware version with fastest read speed?
See title. Is it 1.00? 1.02? Does it even matter?
Re: LG WH14NS40 firmware version with fastest read speed?
Any Ns60 firmware as the guide says
Thanks! I saw in the WH14NS40 1.00 thread that the OP was getting 50 MB/s, but I’m only seeing low 30s MB/s on 1.02 MK. Just wondering if I’m doing something wrong or if 1.00 would be faster?
- Contact:
You did enable speed control in MakeMKV settings, right?tiny_pie wrote: Sun Aug 02, 2020 5:43 ambut I’m only seeing low 30s MB/s on 1.02 MK. Just wondering if I’m doing something wrong
Thanks for the tip! I overlooked it because the setting was not in the GUI. I found the instructions thread though and enabled unlimited speed (0=99). I was able to hit a peak read speed 51.6 MB/s, which is a huge improvement vs beforemike admin wrote: Sun Aug 02, 2020 11:40 amYou did enable speed control in MakeMKV settings, right?tiny_pie wrote: Sun Aug 02, 2020 5:43 ambut I’m only seeing low 30s MB/s on 1.02 MK. Just wondering if I’m doing something wrong
Question: Is there a way to show the average and peak read speed in the logs?
