Now I understand why!
Mamma mia!
It's a bit of an exaggeration!
However, I understand your anxieties and that's why I updated my previous post.
Thanks for the feedback!
Are you trying to play via the Kodi Plex add on?safcsat wrote: ↑Sat Aug 01, 2020 12:57 pmThis is amazing work, so firstly, thank you!
I've installed the latest app for exoplayer, from a few posts back without the debug. Also have created the playercorefactory.xml and copied that over. No matter what I try, when I select to play with external player, or it does it itself as I have a rule in playercorefactory.xml, I get a popup to say external player is active, click ok when playback has ended, but nothing plays. Tried the samples from this thread to be sure it is not related to non-working conversions.
Any ideas?
Shield Pro 2019
Latest Kodi from Play Store
latest exoplayer.apk from this thread.
Ah! I had only tried direct playing from a NAS share within Kodi (mapped the share)Dinst wrote: ↑Sat Aug 01, 2020 1:59 pmAre you trying to play via the Kodi Plex add on?safcsat wrote: ↑Sat Aug 01, 2020 12:57 pmThis is amazing work, so firstly, thank you!
Any ideas?
Shield Pro 2019
I have it working in both, it may have something to do with the way you've mounted your NAS. I was having issues until I mounted my external drive correctly.
This does happen, try clicking play again or closing exoplayer and trying again.Lost_Brit wrote: ↑Sat Aug 01, 2020 2:05 pmHopefully someone can point me to what I'm doing wrong. Using Shield 2019 with LG C8.
I've got ExoPlayer set up as an external player with Kodi, and Exoplayer is launched, but after about 2 seconds, I get a message 'Playback failed'. This doesn't just happen on DV files made with latest MakeMKV, I can't get ExoPlayer to play any files at all.
I get this (playing via Plex inside Kodi) and I just press play again and it plays.Lost_Brit wrote: ↑Sat Aug 01, 2020 2:05 pmHopefully someone can point me to what I'm doing wrong. Using Shield 2019 with LG C8.
