fake playlists - Source Code (2011 - US Retail Amazon) - Java installed
tahlyn
Post by tahlyn » Thu Aug 30, 2018 7:46 pm
Latest version of MakeMKV (1.12.3) and Java version is 1.8.0_181-b13, but no feature movie listed. Link to zip with non-decrypted full disc backup (minus stream folder) and log file.
http://s000.tinyupload.com/?file_id=311 ... 2279564681
thanks.
Re: fake playlists - Source Code (2011 - US Retail Amazon) - Java installed
Post by d00zah » Thu Aug 30, 2018 8:10 pm
No mention of Java being invoked in the log, so it was probably unnecessary?
It may not solve the issue, but there are problems w/ BDs & the latest MakeMKV version... try installing v1.12.2.
Link to old versions in my sig.
tahlyn
Post by tahlyn » Thu Aug 30, 2018 9:21 pm
thanks. Tried versions 1.12.2, 1.12.1, and 1.12.0 from my own backups. Same result. Actually back in October of last year with v1.10.1, I sent this same report to MakeMKV Support email and I was told that it was a really old disc that was not detected by MakeMKV and should be fixed in the next version. I was posting the same report in the forum (updated to latest version of MakeMKV) in case my original report somehow got lost.
I've also tried a custom path on both PCs for Java under Preferences > Protection. Same result.
Just to make sure Java detection was still working, I decided to pull out a couple of movies that had fake playlists that I had successfully saved before, John Wick and John Wick Chapter 2. When I spin up either disc in MakeMKV on either PC, I get this (with or without the custom path):
Using Java runtime from C:\Program Files\Java\jre1.8.0_181\bin\java.exe
and when they're done loading, I see the FPL_MainFeature for both, so I know the Java detection part is working.
tahlyn
Post by tahlyn » Tue Sep 04, 2018 8:08 pm
I tried another program and it gave 2 "good" playlists, 876 and 743. In MakeMKV, both 876 & 743 have the exact same segment order, duration, chapters and size. I successfully saved 743, but I haven't watched it in full to verify that there's no issues.
Total size: 14136768 sectors (27610 MBytes)
Video Blu-ray label: SOURCE_CODE
Media is AACS protected!
Drive supports bus encryption!
AACS MKB version 25
Removed AACS copy protection!
Determined region(s): A
Blu-ray Java signatures fixed!
BD-Live deactivated!
Sony structural BD-J protection removed!
Java BD protection good playlists: 876, 743
Bad sector protection not found.
MakeMKV
Title information
Name: Source Code (English)
Source file name: 00743.mpls
Duration: 1:33:12
Chapters count: 18
Segment count: 7
Segment map: 147,3,141,137,1,142,4
File name: Source_Code_t33.mkv
Title information
Source file name: 00876.mpls
Duration: 1:33:12
Chapters count: 18
Segment count: 7
File name: Source_Code_t42.mkv
Ellsworth2020
Post by Ellsworth2020 » Fri Jul 31, 2020 4:02 pm
876 is the correct one, it includes the Director Commentary track, along with the other audio tracks.
743 is not correct, but I think it gives exactly the same movie, just with no commentary track, and a ton of duplicate subtitle files.
Note that 876 includes the commentary as an audio track, and as a subtitle track.
preserve
Post by preserve » Sat Aug 01, 2020 6:27 am
For additional reference, there are a few topics on this same release:
https://makemkv.com/forum/viewtopic.php?f=8&t=3876
https://makemkv.com/forum/viewtopic.php?f=8&t=17882
Still looking for the Canadian retail correct playlist. Entertainment One release, 200119BRD.
Using: ASUS BW-16D1HT 3.00
