Blu-ray rip succeeds with 1.15.0, fails with 1.15.1 and .2
logic
Post by logic »
So, this is an odd one. I picked up a copy of Honey and Clover S01 the other day, and tried to rip the first disc with MakeMKV 1.15.2 (Linux, Fedora 32, BW-16D1HT 3.10 patched LibreDrive), and it failed partway into the main feature, and I saw some SCSI errors:
Jul 30 15:31:28 mini kernel: sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=8s
Jul 30 15:31:28 mini kernel: sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
Jul 30 15:31:28 mini kernel: sr 2:0:0:0: [sr0] tag#0 Add. Sense: Timeout on logical unit
Jul 30 15:31:28 mini kernel: sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 7f 40 00 00 c0 00
Jul 30 15:31:28 mini kernel: blk_update_request: critical target error, dev sr0, sector 130304 op 0x0:(READ) flags 0x0 phys_seg 26 prio class 0
Well that sucks. Look at the physical disc; no scratches, no fingerprints. Cleaned it, tried again, failed. Try doing a backup instead of an mkv rip (I've had some success with this in the past): that works! Great, now I have a decrypted copy I can work with locally without having the drive or USB bus get in the way.
Try to play the decrypted version with vlc: aaaaaaand, it hates it, because regions. Bleh. Try playing the individual m2ts files with mpv, and everything looks great, no issues. That's promising.
So, try building an mkv from the backup: fails, same error. Huh. That's weird. Downgrade to 1.15.1, same probem. Downgrade to 1.15.0, and...... it works. So, my personal problem is solved, but it seems there's something going on here. :)
MakeMKV logs from 1.15.1 attached. Happy to run additional tests if it'd be helpful.
MakeMKV_log-1.15.1.txt
1.15.1 log - failure
(29.26 KiB) Downloaded 689 times
logic
Re: Blu-ray rip succeeds with 1.15.0, fails with 1.15.1 and .2
Post by logic »
Looks like the same problem with the second disc as well; attached makemkv log from 1.15.2 this time. As before, 1.15.0 worked fine, for grins, I've attached the makemkv log from that version as well.
I assume there is something up with the mastering of this release, since nothing else has been throwing errors like this.
MakeMKV_log-1.15.0.txt
1.15.0 success
(8.93 KiB) Downloaded 696 times
MakeMKV_log-1.15.2.txt
1.15.2 failure
(23.02 KiB) Downloaded 620 times
garretn
Post by garretn »
I've had this issue with a couple different anime releases as well (bearing in mind that I use makemkv for a TON of anime and not much else, so I doubt "anime" has anything to do with anything). I have the same drive. I'm pretty sure it has something to do with Libredrive because one thing -- and only one thing -- has worked for me when this happens:
Rebooting.
The drive is pretty much dead in the water until I reboot, and I can usually rip the same disc just fine the second time around. I also have had luck going back to 1.15.0, but tried upgrading to 1.15.2 for the unrestricted read speed (which works great!), unfortunately this problem did come back with it. This is a summary of my log, most of it just repeats:
MakeMKV v1.15.2 linux(x64-release) started
Using LibreDrive mode (v06.2 id=96929CF53B04)
Error 'Internal error - Operation result is incorrect (132)' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '38535168'
Error 'Posix error - Input/output error' occurred while reading '/dev/sr0' at offset '38535168'
Saving 10 titles into directory <redacted>
AV synchronization issues were found in file '01.mkv' (title #1)
Forced subtitles track #4 turned out to be empty and was removed from output file
Forced subtitles track #6 turned out to be empty and was removed from output file
AV synchronization issues were found in file '02.mkv' (title #2)
... a lot of that, then the same for all titles after...
Suikoman444
Post by Suikoman444 »
Having the exact same issue as above. I've also been ripping a ton of anime and it's happened about a dozen discs so far (out of a couple hundred)
