Smallville Season 1 Disc 3
MaakuKooru
Post by MaakuKooru » Fri Jul 31, 2020 12:14 am
Working on backing up my copies of Smallville, barely made it into season 1 and when I get to disc 3 it only loads 2 of the episodes and a marathon play option for those 2 as playlists. The disc is supposed to have a total of 4 episodes on it...anyone know what's going on?
Re: Smallville Season 1 Disc 3
Post by Woodstock » Fri Jul 31, 2020 12:53 am
Not without information from the debug log.
MaakuKooru
Post by MaakuKooru » Fri Jul 31, 2020 1:46 am
Sorry, I'm pretty new to using the program, is this the info you mean?
Title #1 was added (12 cell(s), 1:28:03)
Title #2 was added (1 cell(s), 0:00:11)
Cells 8-end were skipped due to cell commands (structure protection?)
Title #3 was added (6 cell(s), 0:44:04)
Title #4 was added (6 cell(s), 0:43:59)
Subtitle stream #4 is identical to stream #3 and was skipped
Subtitle stream #5 is identical to stream #3 and was skipped
Subtitle stream #6 is identical to stream #3 and was skipped
That's all that appears after I open the disc
Post by Woodstock » Fri Jul 31, 2020 2:12 am
Did you rip the three titles?
A common setup is to put two-part episodes into a single episode, which would account for 4 episodes. Not being familiar with the series, though, I can't say whether there were any multi-part stories...
MaakuKooru
Post by MaakuKooru » Fri Jul 31, 2020 3:09 am
I did rip all 3, when it finished up I had 3 files, but I ended up with episodes 9 and 10. And a file of 9+10 together.
MaakuKooru
Post by MaakuKooru » Fri Jul 31, 2020 3:23 am
Here's the full debug log, just got that enabled
MakeMKV_log 7.30 Smallville.txt
(7.88 KiB) Downloaded 663 times
Post by Woodstock » Fri Jul 31, 2020 12:45 pm
Take the log and the IFO files, as listed in the FAQ in my signature, and send them to support@makemkv.com so that Mike can look at them, please.
preserve
Post by preserve » Sat Aug 01, 2020 8:16 am
Interesting... I had no problems with this series way back when, and I have no problems with it now. I just loaded Season 1 Disc 3 quickly to check - on the system I checked it, I currently have an old version 1.14.2 installed (given the current issues with 1.15.2, it might be nice for MakeMKV to have standalone distributions to make it easier to switch between versions) - and all 4 episodes load correctly.
I have the original 2003 North America digipak release of this. If you have a later re-release it's possible the discs have changed, and also the discs would be different in other regions. So it's always helpful to post disc info as well in your thread, so that anyone looking to help can compare the exact same release:
Disc Information
Label: SMALLVILLE_SEASON_1_DISC_3
Timestamp: 2003-07-07 19:48:25
Data capacity: 7.17 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Title #1 was added (24 cell(s), 2:55:16)
Title #5 was added (6 cell(s), 0:44:12)
Title #6 was added (6 cell(s), 0:43:01)
Title #7 was added (1 cell(s), 0:00:32)
Title #8 was added (1 cell(s), 0:00:07)
Title #9 was added (1 cell(s), 0:01:08)
Title #10 was added (1 cell(s), 0:00:29)
Using: ASUS BW-16D1HT 3.00
Post by Woodstock » Sat Aug 01, 2020 1:55 pm
You need only install them in different directories... I have five different versions installed right now. They will share a common data directory, but they are otherwise stand-alone.
