I backed up my disk and when I try and play it, the video signal gets very "weird". It looks like one eye is kind of in the middle of the screen and the other eye is split across the top and bottom.
I tried using the backup option and played the MPLS in Kodi and had the same problem -- however the disc plays in 3D just fine from a bluray player.
I'm guessing that there is some sort of mastering error in the streams and that my bluray player is just adapting to it on the fly, but I'm not sure how to resolve the issue.
Video
ID : 4114 (0x1012) / 4113 (0x1011)
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Stereo High@L4.1 / High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : 27
Duration : 1 h 30 min
Bit rate mode : Variable
Bit rate : 45.9 Mb/s / 31.5 Mb/s
Maximum bit rate : 30.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.923
Stream size : 20.0 GiB
format_identifier : HDMV
Source : 00450.m2ts / 00339.m2ts
Trolls World Party 3D - 3D broken
invaderzog
Re: Trolls World Party 3D - 3D broken
FYI - Creating an ISO of the backed up files worked, but I'd still prefer to get it working in a MKV container.
invaderzog
Update: I think MakeMkv 1.15.2 was the issue not the disk...
