ragico
Post by ragico »
RESET_9999 wrote:
Tue Jul 28, 2020 1:52 am
shawnc22 wrote:
Tue Jul 28, 2020 1:39 am
Oh I had no idea the x700 supported single track dual layer files.
The saving private ryan flickering issue is also another big concern to me. too bad it's FEL, I can't test the single layer el+rpu on the x700. But I don't recall that I noticed flickering when I watched the dual layer TS.
I have it in dual layer TS on my x700 and there is no flickering.
So, I did more comparison with my x700 and I just can't get a perfect match with any of the single-layer BL+EL+RPU( FEL or MEL). I'm starting to think that the Shield just can't play them properly because I can get a perfect match with the genuine profile 5 full range files from streaming services but never with the uhd-bd rip. It actually makes sense, maybe the shield was never meant to play dual layer rip.
Using a real profile 5(BL+RPU) test pattern, the Vertex completely fixes the red push issue and the colors match the x700 perfectly.
Shield Vertex fix VS x700 default mode: https://screenshotcomparison.com/comparison/4939
Shield Vertex fix VS Shield RGB bt2020 default: https://screenshotcomparison.com/comparison/4938
test pattern: https://drive.google.com/file/d/1JURFyX ... sp=sharing
Spears & Munsil disc.
I see a red push even with the Vertex.
Shield Vertex fix VS Shield RGB bt2020 default https://screenshotcomparison.com/comparison/4940
Shield Vertex fix VS x700 default mode: https://screenshotcomparison.com/comparison/4941
x700 default mode VS Shield RGB bt2020 default: https://screenshotcomparison.com/comparison/4942
Post by shawnc22 »
Could definitely be the case that the Shield just wasn’t meant to play back these kind of files. There is confirmed support for profile 4 MEL, though, so I’m wondering what kind of media they had in mind for the implementation. The only official profile 4 video I can think of is the lg demo from here: https://4kmedia.org/lg-dolby-vision-uhd-4k-demo/. I haven’t looked at this video closely or compared the playback off anything else to see if there’re any evidence of the red push here.
Post by SamuriHL »
That's really bizarre. That's completely different than the results I saw. I'm not able to take screen shots to show it, but, the picture was identical on the SM benchmark demo between my UB820 and the Shield. And I was not using the Integral 2 to correct anything at that time. And yes, I do get the red push problem in other videos. That Doctor Sleep sample that shawnc22 posted, as an example, I compared with my LG internal player vs the Shield and definitely saw the problem. So I have no idea what the pattern is here.
SamuriHL wrote:
Tue Jul 28, 2020 3:53 pm
The difference can be hard to see but if you compare a scene with a lot of red colors, it's more obvious.
like frame 5066
Post by SamuriHL »
RESET_9999 wrote:
Tue Jul 28, 2020 4:07 pm
like frame 5066
I'll take a look tonight.
shawnc22 wrote:
Tue Jul 28, 2020 3:52 pm
definitely going to try that file. thank's
Darthjipsu
Post by Darthjipsu »
RESET_9999 wrote:
Tue Jul 28, 2020 3:27 pm
I've conduct the same comparison with your pattern DV file.
I compared the mp4 played with my Shield RGB bt2020 and with in-app Philips
Shield Normal VS Philips TV https://screenshotcomparison.com/comparison/4946
And my results seems slightly differents
Cyan is brighter with my shield but i'm not sure about a red push
it's very strange
Darthjipsu wrote:
Tue Jul 28, 2020 5:15 pm
it's very strange
interesting..... yours appear undersaturated compared to the philips and yes indeed, very different than my comparisons but I noticed your taking pictures in a bright room. My pictures were taken in a complete dark room ( black velvet everywhere) without any light. Perhaps thats the difference ? I dont know but I'm clearly getting the same color difference no matter how many comparisons i do.
Also, I assume your camera settings are locked?
EDIT:, you sure the signal is RGB ? I don't know what DV type the Philips tv supports, maybe LLDV ? that would explain why the red color seems ok.
Darthjipsu
RESET_9999 wrote:
Tue Jul 28, 2020 6:01 pm
it's very strange
It's not in a bright room, just ambilight activated. I could try to turn off ambilight.
And yes I locked my camera Settings (ISO, Shutter Speed, Aperture, White Balance)
I will also try later today or tomorrow the video with plex running on Philips to see if the problem come from Multimedia App or Shield TV
lexyz
Post by lexyz »
Very close to what I see on my tv
I can't tell there is any noticeable red push
Bravia internal Plex vs Shield Plex
Bravia's internal apps are brighter, so ignore brightness difference
https://screenshotcomparison.com/comparison/4951
Re:
Darthjipsu wrote:
Tue Jul 28, 2020 6:08 pm
do you have any device that can tell you if you are getting RGB 8bit DV or LLDV 12bit?
lexyz wrote:
Tue Jul 28, 2020 6:35 pm
yeah, with a Sony TV, you shouldn't have any red push with genuine profile 5 files or from any streaming apps.
but thats a huge brightness difference!!
Darthjipsu
RESET_9999 wrote:
Tue Jul 28, 2020 7:26 pm
My TV tells me that I receive 8bit RGB when using Nvidia Shield
Darthjipsu wrote:
Tue Jul 28, 2020 7:30 pm
Interesting. is it an OLED ? I wonder if that could matter.
