shawnc22 wrote: Mon Jul 27, 2020 6:50 pm Yeah that's what I figured, but a comparison of just the FEL tracks on the Shield vs a bluray player should still be valid for our purpose.
I'm not sure if it's possible to really confirm if the Shield actually makes use of the FEL with a picture comparison.
I don't really see a difference in real life. Also the time it takes, when I switch from 1 input to another, is too long to notice any difference. 2 identical tv side by side would probably be better to spot a difference if there is any.
I will try to compare more movies later today or this week.
Comparison FEL 1: https://screenshotcomparison.com/comparison/4909
Comparison FEL 2: https://screenshotcomparison.com/compar ... /picture:1
also tested the doctor sleep famous scene with vertex fix: https://screenshotcomparison.com/comparison/4907
Shield FEL / X700 FEL / x700 RPU Non-standard / AppleTV MA RPU
Image Image Image Image
Post by SamuriHL »
lexyz wrote: Mon Jul 27, 2020 6:43 pm Actually, after I found Stacey Spears comment redarding FEL and MEL I doubt it could be uses for comparison.
Each version was intentionally made with maximum possible quality. So... MEL and FEL BL are not equal - MEL has higher bitrate.
To catch a difference you need to pixel-peeping for compression artifacts.
Peacock feather scene around 3:00 should be suitable for such endeavor.
Yeah that's what I figured, but a comparison of just the FEL tracks on the Shield vs a bluray player should still be valid for our purpose. Actually a comparison of just the MEL and FEL tracks on the Shield should also be of some good use. If they have similar picture like they are supposed to, then it's a good sign for the Shield's FEL capabilities. But if the FEL track looks vastly different, then the EL is probably not being properly applied.
This is what I was thinking, too. It might prove useful. Once I get off work I'll see what I can do tonight.
Post by shawnc22 »
If there is no discernible difference in real-life with a picture comparison, then I'm content :lol:. The rest is just curiosity. Thank you both for taking the time to do the tests!
Post by SamuriHL »
I'm trying to make the MKV's from the SM benchmark UHD and I'm not seeing the MEL tracks listed. Does MakeMKV not recognize them as MEL? I see 2 FEL tracks. If I'm not able to stick the MEL tracks into an MKV I may have to do spot comparisons between the FEL track on my UB820 and the Shield, pausing and switching between them. Which I can do.
Post by shawnc22 »
SamuriHL wrote: Mon Jul 27, 2020 8:27 pm I'm trying to make the MKV's from the SM benchmark UHD and I'm not seeing the MEL tracks listed. Does MakeMKV not recognize them as MEL? I see 2 FEL tracks. If I'm not able to stick the MEL tracks into an MKV I may have to do spot comparisons between the FEL track on my UB820 and the Shield, pausing and switching between them. Which I can do.
Pretty sure it should. Just tested with my old copy of the Last Jedi and MakeMKV correctly labels it as MEL. According to @lexyz's previous post, 20001.m2ts should be the MEL track. Maybe double check with BDInfo to make sure?
Post by SamuriHL »
I would have thought the same thing since 20000 is the FEL track. But 20001 is not showing any DV info at all. I'm scanning the disc with the monkey right now which will spit out a bdinfo report for me.
EDIT:
20000.M2TS 4113 (0x1011) 0x24 HEVC 0.00 0 0 0
20000.M2TS 4117 (0x1015) 0x24 HEVC 0.00 0 0 0
20000.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 0.00 0 0 0
[/code]
<---- END FORUMS PASTE ---->
QUICK SUMMARY:
Disc Title: SPEARS MUNSIL UHDHDR BENCHMARK
Disc Size: 94,135,580,672 bytes
Protection: AACS2(v70)
Playlist: 00092.MPLS
Length: 0:07:45.381
Total Bitrate: 88.48 Mbps
Video: MPEG-H HEVC Video / 0 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 10000nits / HDR10 / BT.2020
Video: * MPEG-H HEVC Video / 0 kbps (0.00%) / 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 10000nits / Dolby Vision / BT.2020
Audio: English / Dolby TrueHD Audio / 5.1 / 48 kHz / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
That's the FEL track.
20001.M2TS 4113 (0x1011) 0x24 HEVC 0.00 0 0 0
20001.M2TS 4117 (0x1015) 0x24 HEVC 0.00 0 0 0
20001.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 0.00 0 0 0
[/code]
QUICK SUMMARY:
Playlist: 00093.MPLS
Length: 0:07:45.381
Total Bitrate: 85.38 Mbps
That in theory should be the MEL track. Yet MakeMKV doesn't register it as such. Whatever. I ripped them both anyway. I'll see what happens.
Post by SamuriHL »
None of it matters anyway. It won't play. I either get playback failed or it plays 2 seconds and hangs. That's with the FEL track. The MEL track as suspected doesn't trigger DV at all and plays in HDR. So much for that fun theory.
Post by shawnc22 »
Ah that's a bummer. Maybe these tracks are just a bit atypical compared to regular movies.
Post by SamuriHL »
Are you suggesting that 10000 nit Dolby Vision files are somehow non-standard?? :D Yea, i know. it was worth a try though.
Post by SamuriHL »
WOA! Ok then. I just fast forwarded a little bit in the video and it plays. Alright then. Maybe we can test this out.
I think something else is wrong with either the single layer el+rpu file or the shield because on the Doctor sleep scene, yes the vertex does reduce the red push but there is still a red tint on the little girl face while on the x700 with a dual-layer profile 7 file, it's totally clean. I would presume it's because of the file because i dont see this problem on streaming apps.
EDIT:
It's not the file.. Just tested it on the x700 and it's identical to the dual layer file. No red artifacts in the face.. Did this issue happen with other movies as well? i dont think its the same issue as the red push, looks more like artifacts.
https://screenshotcomparison.com/comparison/4913
Post by shawnc22 »
RESET_9999 wrote: Mon Jul 27, 2020 9:26 pm I think something else is wrong with either the single layer el+rpu file or the shield because on the Doctor sleep scene, yes the vertex does reduce the red push but there is still a red tint on the little girl face while on the x700 with a dual-layer profile 7 file, it's totally clean. I would presume it's because of the file because i dont see this problem on streaming apps.
EDIT:
Oh I had no idea the x700 supported single track dual layer files. Maybe this is why the nvidia devs stated that getting rid of the BT2020 signal didn't entirely solve the issue and that they're still actively working on it.
shawnc22 wrote: Tue Jul 28, 2020 1:39 am Oh I had no idea the x700 supported single track dual layer files.
yes but only the MEL movies. In .TS/mp4 container only of course.
I dont use my shield to watch DV rip because i have a x700 so, did anyone ever noticed something very obvious like that Doctor Sleep scene where you can tell for sure that something is wrong?
The saving private ryan flickering issue is also another big concern to me. too bad it's FEL, I can't test the single layer el+rpu on the x700. But I don't recall that I noticed flickering when I watched the dual layer TS.
Post by SamuriHL »
I need to dust off the UB820 (literally) and do some real world comparisons because I'm noticing some red tinting in places where it shouldn't be. Sometimes it's almost pink. Having the ability to directly compare the discs on the UB820 with the Shield will be a godsend. I can pause scenes that I am concerned with and directly compare them by switching inputs on the receiver which happens fast. it might be this weekend before I have time to really sit down and do an in depth comparison but I have at least one scene in 2001 that I need to compare asap. Something is definitely wrong. But it only seems to be with file playback. i'm not seeing the same issues with the apps (vudu, netflix etc).
Post by SamuriHL »
Since I had the Spears and Munsil disc out and put the FEL MKV rip out for the shield, I decided to run a few scene comparisons. Only a few just for spot checking, nothing in depth.
First some observations about my setup. I'm running a C8 that has the service menu white point calibrated to D65. I did NOT calibrate the DV modes, however, they ARE using the SM white point adjustment. Given how accurate the C8 is out of the box, this is about as close to reference as you're going to get with these displays, especially when driving content that is 10k nits. Which brings me to my next observation. At 10k nits, we're obviously well into the aggressively tone mapped curve of the C8. Given that I push about 800 nits max out of that thing, obviously it's HIGHLY tone mapped. I use this scene as a torture test for madvr dynamic tone mapping for HDR. I've not really messed with the Dolby Vision version of it other than to do a quick comparison with HDR. On the shield, I did NOT apply the HD Fury change. This is important to note as you'll soon see.
I was looking for specific artifacts here. The red tinting I was talking about tends to happen with partially white backgrounds. Therefore, I limited my testing to 3 scenes and compared the UB820 to the shield. The shield was set to 2160 res, 23.976Hz refresh rate, 12 bit YCbCr output. The UB820 is set similarly. With that out of the way....
I don't have specific time codes for everything. I know 2 of them off the top of my head. 32 seconds and 45 seconds. The 3 scenes are the fence with snow, the horses in the snow, and the deer.
The fence with snow, I usually look at the detail in the snow itself and along the fence posts. I detected no artifacts in this scene in a direct comparison with the UB820. Color representation was accurate. No red push or tint of any kind was detected.
The horse scene is notoriously nasty on tone mapping algorithms. It was designed that way. I focus on the snow in front of the horses to see the detail within the snow. The horses themselves should be quite details even with all the snow noise around them. And the background should not be washed out, even though it is blurry due to the snow. I detected no artifacts in this scene. Color representation was accurate. No red push or tint of any kind was detected.
The deer is a fun one. I like looking at his nose cause it torture tests your black levels. And his antlers have quite a bit of detail. The detail in his fur around his face is also nice to check out. I'm sure you've detected a theme here. I detected no artifacts in this scene. Color representation was accurate. No red push or tine of any kind was detected.
To be clear, I was not pixel peeping here. But these are scenes I'm excruciatingly familiar with from my madvr tone mapping testing. The FEL MKV gave the exact same picture as my UB820 on these particular scenes. We're going to need to do a way more in depth comparison, obviously, but, the spot check passed. Without any HD Fury fixes. Clearly whatever issue we have is not impacting ALL video.
