I have been using MKV for years and have a purchased license. Recently, I've been having errors reading discs causing the ripping operation to fail when copying the .MKV. I have tested the same disc on two different computers with the same result. No issues watching the disc on VLC on the same computer so it shouldn't be a disc or drive issue.
Dell Inspiron PC
Windows 10 Home
makeMKV version 1.15.2
Any info would be great.
Thanks,
Error log:
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL HL-DT-ST DVD+-RW GU90N A1C3' at offset '2642423808'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2642423808'
DEBUG: Code 3221225628 at WeCdm# ?*))&YS;*<2:213131433
DEBUG: Code 100864256 at WeCdm# ?*))&YS;*<2:213131433
DEBUG: Code 0 at kG#"FT(\VWlXS!\Qy[T^:121263820
DEBUG: Code 0 at V{CpqaO}n_H^)_#Xk6F:29393562
DEBUG: Code 0 at kG#"FT(\VWlXS!\Qy[T^:121262900
DEBUG: Code 0 at kG#"FT(\VWlXS!\Qy[T^:213130996
DEBUG: Code 1290246 at kG#"FT(\VWlXS!\Qy[T^:29393286
DEBUG: Code 0 at mDH*7#opV/\*w#Id],b:213132491
DEBUG: Code 0 at mirI$m!:l!nb1uc0(p.,]:29400094
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file C:/Users/skozi/Videos/1. MKV/To be moved/Trolls World Tour/title_t00.mkv
Encountered 14 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
DVD Read error only while using makeMKV
Re: DVD Read error only while using makeMKV
When running VLC in "DVD play mode", it emulates a DVD player... right down to skipping over many types of read errors, so long as they're short in duration.
MakeMKV does not do that - if it encounters an error, it is going to make a few retries, then report the error and abort if that doesn't work.
Have you read the rip error "read me first" yet?
