Is there an SVQ file to make an MKV for the "Knight & Day" Blu Ray?
I have senet my dump but the current posted file still does not work.
Has anyone got thi sto work yet?
Cannot make MKV for "Knight and Day"
Re: Cannot make MKV for "Knight and Day"
Hi!
You'll see several similar posts in the "Blu-ray Error Reports" sub-forum here. It's not yet been resolved...
- Contact:
SVQ is updated.
Excellent! I will be testing this shortly. Thank you!mike admin wrote:SVQ is updated.
OK. This is now working! And what's more, I am so excited to do this rip that I didn't even bother to stop a rip that I am currently doing on my Payback Straight Up HDDVD over an XBOX 360 external HDDVD reader. I just started testing out the HDDVD function tonight on about 10 discs that I own and they all rip fine. I have two instances of MakeMKV up, one is ripping Payback Straight Up on HDDVD and the other is ripping Knight & Day on the internal BD reader. Both are going over eSATA to a 2TB WD Green drive in an external dock. I am in geek heaven. Best $50 I've ever spent.
Here are the messages for Knight & Day now (the SVQs loaded automatically and correctly):
MakeMKV v1.6.2 win(x64-release) started
Downloading latest SVQ(s) to e:\keys ...
Loaded 136 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from ff000007.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00850.mpls was added as title #0
Title #00020.mpls has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00800.mpls is equal to title 00850.mpls and was skipped
Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00250.m2ts was added as title #1
File 00251.m2ts was added as title #2
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00261.m2ts was added as title #3
File 00262.m2ts was added as title #4
File 00263.m2ts was added as title #5
File 00264.m2ts was added as title #6
File 00265.m2ts was added as title #7
Title #00252.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00271.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00268.m2ts was added as title #8
File 00269.m2ts was added as title #9
Title #00270.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
