Dolby Vision and 1.15.1
PanBear
Re: Dolby Vision and 1.15.1
Post by PanBear »
For anyone interested have got DV working on mkv rips through emby player/server with the modded exoplayer in earlier posts and just ticking the use external player option in emby settings 😊
cipher
Post by cipher »
djbuddha wrote:
Sun Jul 26, 2020 9:54 pm
PLEX RUNNING DOLBY VISION AND ATMOS VIA KODI USING THE NEW APK FROM THIS THREAD:
It's FAR from perfect, but I made video showing the following with the 2019 Shield
Link to the video is at the very bottom:
- How to do it (after altering the playcorefactory.xml file for Kodi, it's easier than you think)
- How to fix the sync issue if you fall out of sync when the movie starts (in my testing, this quick method maintains sync throughout the playback)
- Proof that DV is triggered and not faked (bottom left corner using a Vertex 2 showing LLDV running vs running a non-LLDV file)
- Proof that Dolby Atmos is running (I hear it, but the receiver shows it as you'll see in the video).
Notes:
- This is super-alpha. You still can't resume
- This is super-awesome, it means it's possible (will post this on the Plex forum on their Dolby Vision thread for the shield).
To make this APK the default player on Kodi, it's in the thread, but here's what I did to my playercorefactory.xml file (after </players>)
</players>
<rules action="prepend">
<rule video="true" player="dvdplayer">
<rule filename=".*mkv.*|.*HEVC.*|.*hevc.*" player="ExoPlayer"/>
</rule>
</rules>
</playercorefactory>
https://www.dropbox.com/s/tpore7e80euwy ... 5.MOV?dl=0
I was going to wait until Plex officially released a supported update, but if i can use one of my plex clients now then I may have to set this up.
Thanks for testing and confirming this works, djbuddha. Also, good idea to post this on the Plex forums, hopefully it will light a fire under the butts of the devs (as a fellow dev, I say that with the upmost respect!).
chrisandy
Post by chrisandy »
shawnc22 wrote:
Mon Jul 27, 2020 2:03 am
chrisandy wrote:
Mon Jul 27, 2020 1:35 am
Thanks for providing this - added this .xml to the right folder in Kodi but only getting HDR10 (not DV) playback. Something I'm doing wrong?
shawnc22 wrote:
Sat Jul 25, 2020 8:58 pm
Once yusecope's modified exoplayer apk is released and installed on your Shield, you need to make the following changes:
1) Create a playercorefactory.xml file as shown from the example here: https://kodi.wiki/view/HOW-TO:Use_exter ... on_Android
2) Add this entry to the players block:
<player name="ExoPlayer" type="ExternalPlayer" audio="false" video="true">
			<filename>com.google.android.exoplayer2.demo</filename>
			<hidexbmc>true</hidexbmc>
			<playcountminimumtime>120</playcountminimumtime>
		</player>
3) Move the file over to the Shield at /Android/data/org.xbmc.kodi/files/.kodi/userdata
4) Restart Kodi on your Shield and then browse to the mkv you're trying to play, hold down the select button and you should now see a "Play Using" option. Select that and then ExoPlayer to start playing.
Ah apologies, missed that part. Not seeing 'play using' as an option.. is there something I need to do to get ExoPlayer set up?
Post by shawnc22 »
No, if you’re not seeing it after a restart, then you’ve either put the xml in the wrong place or misspelled the name of the file.
Post by SamuriHL »
chrisandy wrote:
Mon Jul 27, 2020 1:44 am
SHIELD mounted NAS drive - basically sharing a folder on my W10 machine via the network which is mounted as a network drive on the SHIELD.
That works for some of us, doesn't seem to for others. Try copying one locally as a test and see if it plays. Then you can narrow down the issue, but, my guess is it's this.
chrisandy
Post by chrisandy »
shawnc22 wrote:
Mon Jul 27, 2020 2:28 am
Ah got it. And just to confirm, this is the .xml I should try, correct? Without any edits?
https://mega.nz/file/9fZ3gCoa#bUL3DYXfc ... TMD7rccfzk
chrisandy
Post by chrisandy »
SamuriHL wrote:
Mon Jul 27, 2020 2:29 am
Got it. But just to confirm I still need to use 'play using Exoplayer' right?
Donpoku
Post by Donpoku »
Post by SamuriHL »
chrisandy wrote:
Mon Jul 27, 2020 2:37 am
Yes, that's where the DV support for MKV is.
djbuddha
Post by djbuddha »
cipher wrote:
Mon Jul 27, 2020 2:08 am
Notes:
</players>
</rule>
</rules>
No worries! I mostly copied this post and put it in the feature request section on the Plex forum (there's a thread about adding DV support already going).
Let's hope they can do it, but this is definitely more than serviceable as a temporary means to enjoy the new-found support for DV!
chrisandy
Post by chrisandy »
SamuriHL wrote:
Mon Jul 27, 2020 2:54 am
Same situation as earlier - not seeing a 'play using..' icon.
I just used that as the .xml. Was there something I was supposed to edit / change / add?
Donpoku
Post by Donpoku »
Post by shawnc22 »
And where are you putting the file?
Post by SamuriHL »
I don't get any play using icon it just opens in exoplayer when I play an mkv in kodi.
Post by shawnc22 »
SamuriHL wrote:
Mon Jul 27, 2020 3:27 am
[I don't get any play using icon it just opens in exoplayer when I play an mkv in kodi.
That test xml I posted does not change the default player to exoplayer. If he's not seeing the play using option to begin with, then changing it to the default player won't help because he's putting the xml in the wrong place.
