Ripping HD DVD disc's with makemkv?
smshafer4
Post by smshafer4 » Sun Jul 26, 2020 1:12 pm
I have been using makemkv for ripping blu ray disk's and have had great luck using it however I'm trying to rip some old HD DVD disc's that I had from years ago and it's not recognizing the disc?
Any thoughts and or solutions? I'm just trying to rip it my Hard Drive. I'm using a Pioneer BDB 212 internal player.
I appreciate your input.
Steve
Re: Ripping HD DVD disc's with makemkv?
Post by Woodstock » Sun Jul 26, 2020 1:32 pm
Does that drive support HD-DVD? I cannot find evidence that it does.
If the drive doesn't do it, MakeMKV won't be able to.
smshafer4
Post by smshafer4 » Sun Jul 26, 2020 6:15 pm
Thanks you, that's what I was thinking. Do you happen to know which drive does as it's worth it to me based on the number of movies I have that are HD DVD's.
thanks
Post by Woodstock » Sun Jul 26, 2020 8:15 pm
After posting my question, I did find a page that referenced a "coming soon" (in 2007) product from Pioneer that supported both BD and HD-DVD that contained "212" in its model number, but I couldn't find any specifications for it.
m20120
Post by m20120 » Thu Jul 30, 2020 3:32 am
I also had a collection of HD DVD discs. I found a cheap used HD DVD drive from the X Box 360 on Ebay. It is a USB external drive and I was able to use it to rip my discs.
