I just wanted to report an issue with the latest version of MakeMKV, version 1.15.2.
Prior to updating everything was working fine as it always has ever since I first downloaded MakeMKV way back when.
After updating and attempting to backup a blu ray, I received an error message stating "Fatal error has occurred, the program will no exit" or something to that effect.
I tried uninstalling\reinstalling, reboot my computer, nothing helped. I then began searching for the previous version, 1.15.1, which is what I had prior, but was unable to locate it.
Using the link in the FAQs, I was able to locate an older version. The latest version I could fine, which I now have installed, is 1.14.7.
After installing 1.14.7 and attempting to backup the same blu rays I was trying to back up previously, it worked like a charm.
Hopefully someone can take a look at this and also, it would be nice if you could update the old versions repository to include some of the latest revisions, including, 1.15.1.
1.15.2 Fatal Error Occured
Re: 1.15.2 Fatal Error Occured
I agree it would be nice if the old versions contained the previous version, I've started keeping the older versions now after I had a similar issue.
I'll send you a PM with the previous version.
Using: ASUS BW-16D1HT 3.00
- Contact:
Please send the debug dump - http://www.makemkv.com/onlinehelp/dump.html
Oh, forgot to move files. Fixed.
Just added a BD drive to my Mac, and am having the same issue.
Anyone have the link to the 1.15.1 version? I searched but cannot find it online.
- Contact:
http://www.makemkv.com/download/old/
But, if you really get this on mac, please do this as well - http://www.makemkv.com/onlinehelp/dump.html
I'm getting this error now too on 1.15.3, I have a dump file but don't know how/where to send it.
I tried attaching to the post, after putting it in a .zip file, but I get an error 'File too large'.
From the thread Mike referenced:
"Even then the dump file is usually too big for e-mail - please use any free and reputable file hosting service as mediafire.com or dropbox.com to store the file and send the link to support@makemkv.com"
My Apologies, I discovered this shortly after I posted. I sent the email with the link to the dump file. Haven't heard anything since but I did at least send it. Thanksd00zah wrote: ↑Fri Oct 02, 2020 7:06 pmFrom the thread Mike referenced:
None necessary.
You will never get a direct response to a dump submission (unless it represents something new/unique?). Just a key download, when applicable.
