PapitaHD
Post by PapitaHD » Tue Jul 21, 2020 7:38 am
I’m trying to mux the movie “The Dark Tower (2017)” to profile 5, using yusesope’s tool (v4 alpha) but I’m getting errors and the result file plays with glitchy, purple and green vertical lines on M9702 and on Panasonic Oled’s internal player. I muxed it with the proper version of tsMuxeR which gives profile 5 DV, and which I’d used successfully for multiple movies.
V3, revision1 of the tool doesn’t give any errors, it finishes the process as intended but results in the same glitchy file.
The source is a full, decrypted UHD BluRay copy, and I also tried to demux the BL and EL with both FFMPEG and EAC3TO and even tried DVDFab’s single layer mp4 mode, but the end result was always the same. I have 2 different backups of the UHD BluRay, the chances are very low that both of them are corrupted.
What could be the issue? I’ve never run into this problem before.
Post by shawnc22 » Tue Jul 21, 2020 3:43 pm
PapitaHD wrote: Tue Jul 21, 2020 7:38 am Hi,
why are you making profile 5 files when you have a M9702?
PapitaHD
Post by PapitaHD » Tue Jul 21, 2020 4:10 pm
shawnc22 wrote: Tue Jul 21, 2020 3:43 pm
[/quote]
I'm making it for a friend, who has a TV which only supports profile 5.
Post by shawnc22 » Tue Jul 21, 2020 4:19 pm
PapitaHD wrote: Tue Jul 21, 2020 4:10 pm I'm making it for a friend, who has a TV which only supports profile 5.
Maybe give v3 of yusecope's tool a try, but if dvdfab's method is also failing and other titles have worked with your exact same worflow, then it's likely that this title is just an edge case that may require further looking into.
kazuma
Post by kazuma » Tue Jul 21, 2020 5:20 pm
yusecope is useless for lg C9? am i right? i can better use command>profile 7?
userr
Post by userr » Wed Jul 22, 2020 1:54 pm
I apologize if this has been asked before, maybe several times.
In theory, a profile 4 played on the 2019 shield is or is not the same quality/full viewing experience as a UHD disc (profile 7 i assume) played on lets say x700?
userr
Post by userr » Thu Jul 23, 2020 2:19 pm
RESET_9999 wrote: Tue Jul 07, 2020 2:13 pm
it plays both mp4 and ts dual-layer profile 7 DV. But with Atmos + subs, only in a TS container.
it works via the network but not so well, thanks to the slow 100mbps ethernet port. No plex app, unfortunately.
the only downside is the bug that won't let you play 2 movies/files without having to reboot the player.
You say it has no plex app, but can it connect to a local plex-server and just play the files on there?
With the new mkv spec out/coming out, would a mkv ripped with makemkv 1.15.2 be playable on it?
Post by RESET_9999 » Thu Jul 23, 2020 4:16 pm
userr wrote: Thu Jul 23, 2020 2:19 pm
I'm not sure, I don't use the x700 network at all.
userr wrote: Thu Jul 23, 2020 2:19 pm With the new mkv spec out/coming out, would a mkv ripped with makemkv 1.15.2 be playable on it?
I tried that last night and it only played in HDR10.
But just like tsMuxer, the x700 does not support Atmos in a MKV container so a DV mkv would be useless if you want Atmos+DV.
Post by shawnc22 » Sat Jul 25, 2020 6:03 pm
@SamuriHL and @RESET9999, do either of you happen to have Saving Private Ryan ripped? I’m curious to see if the red push workaround also solved the flickering issues that was only found on this title.
Post by SamuriHL » Sat Jul 25, 2020 6:49 pm
Don't have that one on UHD.
Post by shawnc22 » Sat Jul 25, 2020 9:02 pm
SamuriHL wrote: Sat Jul 25, 2020 6:49 pm Don't have that one on UHD.
If you have time, would you mind trying this sample from Saving Private Ryan?
https://mega.nz/file/8XZljQgZ#P2xzsRWST ... 5fCW9zZa_8
Sorry it's a bit large, but for some reason I had trouble cutting it down to anything shorter than 60s. With the Shield currently as is, you should see a lot of flickering throughout the scene. The same file played through the LG internal player doesn't display this behavior. Hoping it's the same issue that's causing the red push.
Post by SamuriHL » Sat Jul 25, 2020 9:35 pm
shawnc22 wrote: Sat Jul 25, 2020 9:02 pm
Watching Enter the Dragon at the moment (Gotta love Bruce Lee's greatest hits collection) but when I'm done with that I can certainly give it a try and see what happens.
Post by SamuriHL » Sat Jul 25, 2020 10:29 pm
Not the news you wanted to hear I'm sure, but, the HDFury does not do anything with the flickering at all. It's there either way.
Post by shawnc22 » Sat Jul 25, 2020 11:09 pm
SamuriHL wrote: Sat Jul 25, 2020 10:29 pm Not the news you wanted to hear I'm sure, but, the HDFury does not do anything with the flickering at all. It's there either way.
Ah no worries, thanks for testing! Just adds to the mystery of the Shield's DV capabilities :lol:
Post by SamuriHL » Sat Jul 25, 2020 11:15 pm
shawnc22 wrote: Sat Jul 25, 2020 11:09 pm
I know right? :D But right now, I'm a HAPPY boy with the Shield DV capabilities. Played a bit of 1917 (it's SO gorgeous) and switched over to Top Gun for a full DV viewing. :D
