RESOLVED - Knight and Day (U.S. version)
setarip_old
#1 Post by setarip_old » Wed Dec 01, 2010 12:27 am
Although BD+ information in the "News and Announcements" sub-forum specifically states that an SVQ for "Knight and Day" is present in the download (The auto-DL finally works for me), MakeMKV v.1.62 (with the latest SVQ installed) fails to decrypt this AACS/MKB v.19 while presenting the following error:
MakeMKV v1.6.2 win(x64-release) started
Backing up disc into folder "E:/_NewBluRayTest/KnightAndDay_Fox"
Downloading latest SVQ(s) to E:/___Temp/MakeMKV_SVQ\SVQ ...
Loaded 45 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as E:/___Temp/MakeMKV_SVQ\Dump/dump_Knight_and_Day_6EB00C496699071E.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Backup failed
I have submitted the dump...
50CalAL
Re: Knight and Day (U.S. version)
#2 Post by 50CalAL » Thu Dec 02, 2010 7:35 am
I'm having a similar problem. Using MakeMKV 1.6.2 for Mac, the auto DL of the svq does work for me but still fails to decrypt the BD+ for this movie. I even manually downloaded the svq from http://www.makemkv.com/svq/dsall.svq?1 and http://www.makemkv.com/svq/dsall.svq?2 just to be sure but still no luck.
I also sent the BD+ dump to svq@makemkv.com.
MakeMKV v1.6.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/50CalAL/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH08LS20 1.00" opened in OS access mode.
Loaded 121 SVQ file(s)
DEBUG: Code 0 at 9=wXDdcJO*XFuB-d:121266557
DEBUG: Code 0 at 9=wXDdcJO*XFuB-d:121264556
DEBUG: Code 0 at 9=wXDdcJO*XFuB-d:29400761
DEBUG: Code 0 at Km8J@u3w}@NKp+6r1*:29397472
Saved BD+ dump file as /Users/50CalAL/Documents/BD Dumps/dump_Knight_and_Day_6EB00C496699071E.tgz
DEBUG: Code 0 at 2Qz]0:?w{[bdz/z@:29396943
jurassic3
#3 Post by jurassic3 » Fri Dec 03, 2010 2:26 am
I'm having the same problem with Knight and Day:
Loaded 58 SVQ file(s)
BD+ dump directory is not set in preferences, BD+ dump not saved
goingbust
#4 Post by goingbust » Fri Dec 03, 2010 3:03 am
I'm getting the same thing. I sent in the dump file.
Axehandler
#5 Post by Axehandler » Fri Dec 03, 2010 4:18 am
MakeMKV v1.6.2 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Axehandler/MakeMKV_log.txt
Opening files on harddrive at E:/@BR Movies/backup/KNIGHT_AND_DAY/
Loaded 170 SVQ file(s)
DEBUG: Code 0 at E3&7p;d(9D?/y(>9:121266557
DEBUG: Code 0 at E3&7p;d(9D?/y(>9:121264556
DEBUG: Code 0 at E3&7p;d(9D?/y(>9:29400761
DEBUG: Code 0 at (>(Je^OcfgvorBu[}I:29397472
Saved BD+ dump file as C:/Program Files/MakeMKV/Dumps/dump_Knight_and_Day_484E3DCFAD8AC0EE.tgz
DEBUG: Code 0 at K6"(!$2zOhQ~5pHr:29396943
Just curious why there is such a disparity between the number of SQV's loaded? (Example mine is - Loaded 170 SVQ file(s))
Also When downloading the current SQV from the website - I should put it in the SQV folder I setup - correct? (I currently copy it into main folder and sqv folder)
Axe
setarip_old
#6 Post by setarip_old » Fri Dec 03, 2010 5:01 am
@Axehandler
In addition to the latest SVQ (that contains 45 references) You undoubtedly have a couple/few older .SVQs in the same folder.
Yes, you should save it to the same folder as you created under "SVQ Files Directory" in MakeMKV'>>Preferences>>BD+
BTW - It's "SVQ"...
#7 Post by mike admin » Sat Dec 04, 2010 8:16 am
SVQ file is now updated.
setarip_old
#8 Post by setarip_old » Sat Dec 04, 2010 9:01 am
Another mountain successfully climbed ;>}
goingbust
#9 Post by goingbust » Sat Dec 04, 2010 9:19 am
setarip_old wrote:Another mountain successfully climbed ;>}
Yep. The rip I have on my disk now is perfect and correct.
50CalAL
Re: RESOLVED - Knight and Day (U.S. version)
#10 Post by 50CalAL » Sat Dec 04, 2010 1:41 pm
Thanks mike, works great now!
