A Simple Favor (US Retail)
XrayDoc88
Re: A Simple Favor (US Retail)
#31 Post by XrayDoc88 » Fri Jul 24, 2020 6:24 pm
I don't have an elegant way of checking the segment maps. This is what I did. First I clicked on each chapter when playing the Blu-ray disc and also when streaming 422 through PLEX. Every chapter start matched, except chapter 6. Then I started watching chapter 5 on both devices. They start out the same, but near the end of chapter 5, the 422 segment map deviates from the Blu-ray disc. I was only looking at the video without any sound. I don't know if the dialog of the different scenes made any sense at that point in the movie.
XrayDoc88
#32 Post by XrayDoc88 » Fri Jul 24, 2020 8:30 pm
I've come to the following conclusions:
1. There are more than one US retail versions and the segment numbers are different for the same scenes.
2. The latest version of MakeMKV identifies 00422.mpls as the correct segment map. This is definitely different (wrong) for my Blu-ray disc.
3. The correct map for my disc is 00308.mpls. At least I haven't found any discrepancies so far, and the end of chapter 5 now matches the Blu-ray disc.
Title information
Name: A Simple Favor
Source file name: 00308.mpls
Duration: 1:56:50
Chapters count: 16
Segment count: 15
Segment map: 514,511,509,510,504,513,501,506,507,515,505,502,508,512,503
File name: A Simple Favor_t83.mkv
If anyone can confirm, please speak up!
preserve
#33 Post by preserve » Sat Jul 25, 2020 12:58 pm
Well shoot, you're absolutely right. "FPL_MainFeature" is NOT correct.
I thought that the comments came from Java identification that was on the disc itself, meaning that they were supposed to be correct? I wonder if any more of my rips where I have trusted this are incorrect as well.
Edit 1: I have submitted the requested files for this disc per the Fake Playlist thread.
Edit 2: And I have confirmed that 308 is correct by watching it side by side from start to finish.
Title information
Name: A Simple Favor (English)
Duration: 1:56:50
Chapters count: 16
Segment count: 15
File name: A Simple Favor_t116_s00308.mkv
Saving 1 titles into directory E:/Video/A Simple Favor
AV sync issue in stream 2,3 at 0:08:37.088 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 4 at 0:08:37.056 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 2,3 at 0:15:54.432 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8.994ms
AV sync issue in stream 4 at 0:15:54.432 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 1 at 0:15:54.370 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.161ms
AV sync issue in stream 2,3 at 0:18:31.744 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8.994ms
AV sync issue in stream 4 at 0:18:31.744 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 1 at 0:18:31.694 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.161ms
AV sync issue in stream 2,3 at 0:35:59.296 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8.994ms
AV sync issue in stream 4 at 0:35:59.296 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.005ms
AV sync issue in stream 1 at 0:35:59.240 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.161ms
AV sync issue in stream 2,3 at 0:39:21.568 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +9ms
AV sync issue in stream 4 at 0:39:21.568 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 1 at 0:39:21.526 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.166ms
AV sync issue in stream 2,3 at 1:10:50.752 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to +8.997ms
AV sync issue in stream 4 at 1:10:50.752 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.002ms
AV sync issue in stream 1 at 1:10:50.705 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.163ms
AV synchronization issues were found in file 'A Simple Favor_t116_s00308.mkv' (title #117)
Forced subtitles track #6 turned out to be empty and was removed from output file
1 titles saved
Using: ASUS BW-16D1HT 3.00
Luey81
#34 Post by Luey81 » Thu Mar 18, 2021 12:59 am
This worked for me:
Retail version of A Simple Favor - Blu-Ray/DVD/Digital copy - UPC 031398295259:
Blu-Ray
MPLS 00859.mpls
Duration: 1:56:50
Chapters Count 16
Segment Count: 15
Segment map: 514,501,510,508,515,502,506,505,509,507,512,504,513,511,503
