I'm just copying main movie. I've cleaned the disk. Any suggestions?
Evaluation version, 27 day(s) out of 30 remaining
File 00000.mpls was added as title #0
Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #1
File 00007.m2ts was added as title #2
Title #00008.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Blu-Ray/FOOLS_GOLD
Error 'Scsi error - MEDIUM ERROR:1180' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '16457005056'
Failed to save title 0 to file D:/Blu-Ray/FOOLS_GOLD/title00.mkv
0 titles saved, 1 failed
Fool's Gold
setarip_old
Re: Fool's Gold
Hi!
Despite the fact that you cleaned the disc, it might be worthwhile to carefully examine it for fingerprints, smudges, etc, as well as for physical damage.
Also try increasing the number of retries to 5 or ten...
