1.15.2 Application Failed to Initialize
Running CentOS 7. I just downloaded and built Makemkv 1.15.2, and when I started the application, I get a popup saying
"The Application failed to initialize." I went back and rebuilt 1.15.1, and it's working fine.
I need some help/guidance please on what to do to upgrade to 1.15.2.
- Contact:
Re: 1.15.2 Application Failed to Initialize
This means that you are using libmakemkv from 1.15.1 and makemkvcon from 1.15.2 . Somehow, the library was not updated.
Yes, that's exactly what happened, but I don't know why (I am not a C++ coder).
makemkv-oss 1.1.5.2 does not compile for me on Centos 7. I saved the output to a log, and grepped "error:" out of the log,
and here's what I got:
/libmakemkv/inc/lgpl/stdstring.h:67:29: error: expected ‘,’ or ‘...’ befor./libmakemkv/inc/lgpl/stdstri./libmakemkv/inc/lgpl/./libmakemkv/inc/lgpl/stdstring.h:67:29: e
./libmakemkv/inc/lgpl/stdstring.h:67:29: error: expected ‘,’ or ‘...’ before ‘&&’ token
./libmakemkv/inc/lgpl/stdstring.h:67:37: error: invalid constructor; you probably meant ‘buf::string (const b
uf::string&)’
./libebml/inc/ebml/EbmlElement.h:387:118: error: ‘nullptr’ was not declared in this scope
./libebml/inc/ebml/EbmlBinary.h:80:19: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlBinary.cpp:45:32: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlBinary.cpp:51:30: error: ‘nullptr’ was not declared in this scope
uf::string&)’
./libebml/inc/ebml/EbmlCrc32.h:105:50: error: ‘nullptr’ was not declared in this scope
./libebml/inc/ebml/EbmlCrc32.h:135:54: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlContexts.cpp:48:71: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlContexts.cpp:48:80: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlContexts.cpp:48:113: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlContexts.cpp:50:132: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlContexts.cpp:50:165: error: ‘nullptr’ was not declared in this scope
uf::string&)’
./libebml/inc/ebml/MemIOCallback.h:54:3: error: looser throw specifier for ‘virtual libebml::MemIOCallback::~
MemIOCallback()’
./libebml/inc/ebml/IOCallback.h:54:11: error: overriding ‘virtual libebml::IOCallback::~IOCallback() throw
libebml/src/EbmlCrc32.cpp:220:10: error: ‘Pad’ does not name a type
libebml/src/EbmlCrc32.cpp:221:9: error: ‘Pad’ was not declared in this scope
libebml/src/EbmlCrc32.cpp:221:16: error: ‘nullptr’ was not declared in this scope
libebml/src/EbmlCrc32.cpp:226:17: error: type ‘<type error>’ argument given to ‘delete’, expected pointer
uf::string&)’
makemkv-oss 1.15.1 compiles cleanly, no problem.
I can provide the entire log file if that helps. Thanks!
uf::string&)’
uf::string&)’
uf::string&)’
MemIOCallback()’
uf::string&)’
- Contact:
Yes, this and configure.log to support@makemkv.com. Thanks!
[SOLVED] 1.15.2 Application Failed to Initialize
Per Mike's help, on my CentOS 7 system,
I configured makemkv-oss like this: (adding CFLAGS="-std=c++11")
CFLAGS="-std=c++11" ./configure
and makemkv compiled and ran just fine.
Hello xr200,
I get the same error but this flag doesn't solve my problem. I use Xubuntu 20 Focal Fossa with Luks filesystem.
I also will send the logfile to makemkv-support.
Try this for Mint:
1) Uninstall 1.15.1
2) Run
sudo apt-get install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev qtbase5-dev zlib1g-dev
3) Run from makemkv-oss source package:
CFLAGS="-std=gnu++11" ./configure
make
sudo make install
4) Run from makemkv-bin source package:
make
sudo make install
Worked for me
1) Uninstall 1.15.1
2) Run
make
sudo make install
make
sudo make install
Worked for me
I'm still having issues installing version 1.15.2.
I'm on Ubuntu 16.04.7 LTS
I tried both:
AND
it seems like it compiles successfully but when I run "sudo make install" I get:
autoxxx/install-sh -c -D -m 644 out/libdriveio.so.0 /usr/lib/libdriveio.so.0
autoxxx/install-sh: invalid option: -D
Makefile:48: recipe for target 'install' failed
make: *** [install] Error 1
How do I unstall 1.15.1?
I tried both:
AND
Don't need to uninstall.
I had the same issue with 1.15.3 on Fedora after using this for the past 4 years. 1.14.5 worked fine from an install a year ago, but I recently installed 1.15.3 and it failed with the same error.
Research revealed that I had duplicate library files in /usr/lib and /usr/lib64.
I deleted libmakemkv.so.1, libdriveio.so.0, and libmmbd.so.0 from both /usr/lib and /usr/lib64.
I then did a new "sudo make install" in both the makemkv-oss-1.15.3 directory and the makemkv-bin-1.15.3 directory and all was good.
Maybe the same will work for you.
