never benn able tu open a blu-ray since version 1.60
rlebel
Post by rlebel »
No matter de blu-ray movie, it freeze over the decryption of 0001.mets file, remaining time going higher and higher
Re: never benn able tu open a blu-ray since version 1.60
Post by SamuriHL »
What happens if you use IMGBurn to make an ISO image of one of these discs? Is it able to create the image successfully? I'm only suggesting this as a test. *USUALLY* when we see these kinds of problems it comes down to a few things....either a bad disc, a slowly dying drive, or filters that are interfering with the drive's proper operation. It's extremely rare for it to be caused by the software doing the ripping.
rlebel
Post by rlebel »
IMGBurn freeze in the screen "Getting track information"
- Also Power DVD can not open any blu-ray
- Plus I have been able to use MakeMKV to process standard dvd
Post by SamuriHL »
Then unfotunately it's not a MakeMKV issue. It's either your disc, drive, or filters causing problems.
rlebel
Post by rlebel »
What do you mean by "filters causing problems"
Post by SamuriHL »
Some software installs filters....basically drivers...that can potentially interfere with ripping. ImgBurn can display a list of filters that are installed. It's not necessarily the issue, but, there are some badly behaved filter drivers out there.
rlebel
Re: never been able tu open a blu-ray since version 1.60
Post by rlebel »
Thank you, i will search in that direction
setarip_old
Post by setarip_old »
@rlebel
Hi!
Sounds like your Blu-ray drive is dying...
Post by SamuriHL »
setarip_old wrote:@rlebel
Hi!
I missed that edit to the post. Yes, I would agree here, as well.
rlebel
Post by rlebel »
Finally i bought a new drive and everything work's fine !
setarip_old
Glad to hear that my speculation was correct ;>}
