shawnc22 wrote:
Sat Jul 18, 2020 11:15 pm
Nice comparisons! have you been able to do any additional comparisons with the shield+vertex vs x700 on FEL titles?
No, but I will now that I can get accurate colors with the Shield.
Post by shawnc22 »
RESET_9999 wrote:
Sat Jul 18, 2020 11:29 pm
fingers crossed for incidental FEL support on the Shield :D
Epedemic
Post by Epedemic »
RESET_9999 wrote:
Sat Jul 18, 2020 9:20 pm
So I made some color comparison tests with my HDfury Vertex on the Shield and the Sony x700 which accurately play DV.
Using the Vertex scaler, I removed the BT2020 flag from the RGB 8BIT Dolby vision signal and bingo!! the red push is gone.
No doubt in my mind this is the problem.
Shield RGB 8 BIT VERTEX FIX VS Shield RGB 8bit BT2020 DEFAULT mode
https://screenshotcomparison.com/comparison/4609
Shield RGB 8 BIT VERTEX FIX VS Sony X700RGB 8 bit DEFAULT mode
https://screenshotcomparison.com/comparison/4610
Shield RGB 8bit BT2020 DEFAULT VS Sony X700RGB 8 bit DEFAULT mode
https://screenshotcomparison.com/comparison/4611
Very nice work! BTW, do you have a chromecast ultra to try the same thing on? It also triggers BT2020 on my E6 when outputting DV.
Post by SamuriHL »
Maybe I missed it so apologies for being lazy and not searching right now, but what did you do on the vertex to remove the bt2020 flag? I'd like to try that with my integral 2. Thanks!!
Epedemic wrote:
Mon Jul 20, 2020 9:57 am
No, I don't own a Chromecast Ultra.
SamuriHL wrote:
Mon Jul 20, 2020 11:39 am
in the scaler tab, you select ''RGB FULL'' for colorspace and ''follow'' for deep color.
Post by SamuriHL »
Awesome, thanks. Will try that when I get a free minute.
EDIT: Brilliant! I just tried it out on a few videos, and it seems to work. This makes the shield usable for DV until they provide a proper fix.
PapitaHD
Post by PapitaHD »
I’m trying to mux the movie “The Dark Tower (2017)” to profile 5, using yusesope’s tool (v4 alpha) but I’m getting errors and the result file plays with glitchy, purple and green vertical lines on M9702 and on Panasonic Oled’s internal player. I muxed it with the proper version of tsMuxeR which gives profile 5 DV, and which I’d used successfully for multiple movies.
V3, revision1 of the tool doesn’t give any errors, it finishes the process as intended but results in the same glitchy file.
The source is a full, decrypted UHD BluRay copy, and I also tried to demux the BL and EL with both FFMPEG and EAC3TO and even tried DVDFab’s single layer mp4 mode, but the end result was always the same. I have 2 different backups of the UHD BluRay, the chances are very low that both of them are corrupted.
What could be the issue? I’ve never run into this problem before.
Post by shawnc22 »
PapitaHD wrote:
Tue Jul 21, 2020 7:38 am
why are you making profile 5 files when you have a M9702?
PapitaHD
Post by PapitaHD »
shawnc22 wrote:
Tue Jul 21, 2020 3:43 pm
[/quote]
I'm making it for a friend, who has a TV which only supports profile 5.
Post by shawnc22 »
PapitaHD wrote:
Tue Jul 21, 2020 4:10 pm
Maybe give v3 of yusecope's tool a try, but if dvdfab's method is also failing and other titles have worked with your exact same worflow, then it's likely that this title is just an edge case that may require further looking into.
kazuma
Post by kazuma »
yusecope is useless for lg C9? am i right? i can better use command>profile 7?
userr
Post by userr »
I apologize if this has been asked before, maybe several times.
In theory, a profile 4 played on the 2019 shield is or is not the same quality/full viewing experience as a UHD disc (profile 7 i assume) played on lets say x700?
userr
Post by userr »
RESET_9999 wrote:
Tue Jul 07, 2020 2:13 pm
it plays both mp4 and ts dual-layer profile 7 DV. But with Atmos + subs, only in a TS container.
it works via the network but not so well, thanks to the slow 100mbps ethernet port. No plex app, unfortunately.
the only downside is the bug that won't let you play 2 movies/files without having to reboot the player.
You say it has no plex app, but can it connect to a local plex-server and just play the files on there?
With the new mkv spec out/coming out, would a mkv ripped with makemkv 1.15.2 be playable on it?
userr wrote:
Thu Jul 23, 2020 2:19 pm
I'm not sure, I don't use the x700 network at all.
I tried that last night and it only played in HDR10.
But just like tsMuxer, the x700 does not support Atmos in a MKV container so a DV mkv would be useless if you want Atmos+DV.
Post by shawnc22 »
@SamuriHL and @RESET9999, do either of you happen to have Saving Private Ryan ripped? I’m curious to see if the red push workaround also solved the flickering issues that was only found on this title.
