#2686 Post by shawnc22 » Sat Jul 18, 2020 11:31 pm
RESET_9999 wrote:
Sat Jul 18, 2020 11:29 pm
shawnc22 wrote:
Sat Jul 18, 2020 11:15 pm
Nice comparisons! have you been able to do any additional comparisons with the shield+vertex vs x700 on FEL titles?
No, but I will now that I can get accurate colors with the Shield.
fingers crossed for incidental FEL support on the Shield :D
Epedemic
#2687 Post by Epedemic » Mon Jul 20, 2020 9:57 am
RESET_9999 wrote:
Sat Jul 18, 2020 9:20 pm
So I made some color comparison tests with my HDfury Vertex on the Shield and the Sony x700 which accurately play DV.
Using the Vertex scaler, I removed the BT2020 flag from the RGB 8BIT Dolby vision signal and bingo!! the red push is gone.
No doubt in my mind this is the problem.
Shield RGB 8 BIT VERTEX FIX VS Shield RGB 8bit BT2020 DEFAULT mode
https://screenshotcomparison.com/comparison/4609
Shield RGB 8 BIT VERTEX FIX VS Sony X700RGB 8 bit DEFAULT mode
https://screenshotcomparison.com/comparison/4610
Shield RGB 8bit BT2020 DEFAULT VS Sony X700RGB 8 bit DEFAULT mode
https://screenshotcomparison.com/comparison/4611
Very nice work! BTW, do you have a chromecast ultra to try the same thing on? It also triggers BT2020 on my E6 when outputting DV.
#2688 Post by SamuriHL » Mon Jul 20, 2020 11:39 am
Maybe I missed it so apologies for being lazy and not searching right now, but what did you do on the vertex to remove the bt2020 flag? I'd like to try that with my integral 2. Thanks!!
#2689 Post by RESET_9999 » Mon Jul 20, 2020 2:10 pm
No, I don't own a Chromecast Ultra.
in the scaler tab, you select ''RGB FULL'' for colorspace and ''follow'' for deep color.
#2690 Post by SamuriHL » Mon Jul 20, 2020 3:20 pm
Awesome, thanks. Will try that when I get a free minute.
EDIT: Brilliant! I just tried it out on a few videos, and it seems to work. This makes the shield usable for DV until they provide a proper fix.
PapitaHD
#2691 Post by PapitaHD » Tue Jul 21, 2020 7:38 am
I’m trying to mux the movie “The Dark Tower (2017)” to profile 5, using yusesope’s tool (v4 alpha) but I’m getting errors and the result file plays with glitchy, purple and green vertical lines on M9702 and on Panasonic Oled’s internal player. I muxed it with the proper version of tsMuxeR which gives profile 5 DV, and which I’d used successfully for multiple movies.
V3, revision1 of the tool doesn’t give any errors, it finishes the process as intended but results in the same glitchy file.
The source is a full, decrypted UHD BluRay copy, and I also tried to demux the BL and EL with both FFMPEG and EAC3TO and even tried DVDFab’s single layer mp4 mode, but the end result was always the same. I have 2 different backups of the UHD BluRay, the chances are very low that both of them are corrupted.
What could be the issue? I’ve never run into this problem before.
#2692 Post by shawnc22 » Tue Jul 21, 2020 3:43 pm
why are you making profile 5 files when you have a M9702?
PapitaHD
#2693 Post by PapitaHD » Tue Jul 21, 2020 4:10 pm
[/quote]
I'm making it for a friend, who has a TV which only supports profile 5.
#2694 Post by shawnc22 » Tue Jul 21, 2020 4:19 pm
Maybe give v3 of yusecope's tool a try, but if dvdfab's method is also failing and other titles have worked with your exact same worflow, then it's likely that this title is just an edge case that may require further looking into.
kazuma
#2695 Post by kazuma » Tue Jul 21, 2020 5:20 pm
yusecope is useless for lg C9? am i right? i can better use command>profile 7?
userr
#2696 Post by userr » Wed Jul 22, 2020 1:54 pm
I apologize if this has been asked before, maybe several times.
In theory, a profile 4 played on the 2019 shield is or is not the same quality/full viewing experience as a UHD disc (profile 7 i assume) played on lets say x700?
userr
#2697 Post by userr » Thu Jul 23, 2020 2:19 pm
RESET_9999 wrote:
Tue Jul 07, 2020 2:13 pm
it plays both mp4 and ts dual-layer profile 7 DV. But with Atmos + subs, only in a TS container.
it works via the network but not so well, thanks to the slow 100mbps ethernet port. No plex app, unfortunately.
the only downside is the bug that won't let you play 2 movies/files without having to reboot the player.
You say it has no plex app, but can it connect to a local plex-server and just play the files on there?
With the new mkv spec out/coming out, would a mkv ripped with makemkv 1.15.2 be playable on it?
#2698 Post by RESET_9999 » Thu Jul 23, 2020 4:16 pm
I'm not sure, I don't use the x700 network at all.
I tried that last night and it only played in HDR10.
But just like tsMuxer, the x700 does not support Atmos in a MKV container so a DV mkv would be useless if you want Atmos+DV.
#2699 Post by shawnc22 » Sat Jul 25, 2020 6:03 pm
@SamuriHL and @RESET9999, do either of you happen to have Saving Private Ryan ripped? I’m curious to see if the red push workaround also solved the flickering issues that was only found on this title.
#2700 Post by SamuriHL » Sat Jul 25, 2020 6:49 pm
Don't have that one on UHD.
