never benn able tu open a blu-ray since version 1.60
rlebel
#1 Post by rlebel » Wed Dec 01, 2010 1:25 am
No matter de blu-ray movie, it freeze over the decryption of 0001.mets file, remaining time going higher and higher
Re: never benn able tu open a blu-ray since version 1.60
#2 Post by SamuriHL » Wed Dec 01, 2010 1:34 am
What happens if you use IMGBurn to make an ISO image of one of these discs? Is it able to create the image successfully? I'm only suggesting this as a test. *USUALLY* when we see these kinds of problems it comes down to a few things....either a bad disc, a slowly dying drive, or filters that are interfering with the drive's proper operation. It's extremely rare for it to be caused by the software doing the ripping.
rlebel
#3 Post by rlebel » Wed Dec 01, 2010 3:00 am
IMGBurn freeze in the screen "Getting track information"
- Also Power DVD can not open any blu-ray
- Plus I have been able to use MakeMKV to process standard dvd
#4 Post by SamuriHL » Wed Dec 01, 2010 3:02 am
Then unfotunately it's not a MakeMKV issue. It's either your disc, drive, or filters causing problems.
rlebel
#5 Post by rlebel » Wed Dec 01, 2010 3:06 am
What do you mean by "filters causing problems"
#6 Post by SamuriHL » Wed Dec 01, 2010 3:15 am
Some software installs filters....basically drivers...that can potentially interfere with ripping. ImgBurn can display a list of filters that are installed. It's not necessarily the issue, but, there are some badly behaved filter drivers out there.
rlebel
Re: never been able tu open a blu-ray since version 1.60
#7 Post by rlebel » Wed Dec 01, 2010 3:20 am
Thank you, i will search in that direction
setarip_old
#8 Post by setarip_old » Wed Dec 01, 2010 4:02 am
@rlebel
Hi!
Sounds like your Blu-ray drive is dying...
#9 Post by SamuriHL » Wed Dec 01, 2010 1:49 pm
setarip_old wrote:@rlebel
Hi!
I missed that edit to the post. Yes, I would agree here, as well.
rlebel
#10 Post by rlebel » Thu Dec 09, 2010 11:32 pm
Finally i bought a new drive and everything work's fine !
setarip_old
#11 Post by setarip_old » Fri Dec 10, 2010 4:03 am
Glad to hear that my speculation was correct ;>}
