Selecting tracks
Stryker412
Selecting tracks
This might be a dumb question but I never really looked in to it. I'm in the process of ripping a show I just got on BD. It has both DTS-MA and Core audio. I only want the core audio. Is there a way to auto select JUST that track for each episode? I've been manually deselecting it and it gets tedious.
Re: Selecting tracks
Changing default track selection
Under Preferences > General, select 'Expert Mode' to expose the 'Advanced' tab, which contains 'Default selection rule'. Modify per thread linked above.
Stryker412
Ok thanks, this is a little confusing. So does this look correct?
-sel:all,+sel:(favlang|eng),-sel:(havemulti|havecore),-sel:mvcvideo,=100:all,-10:favlang
viewtopic.php?f=6&t=21966&p=88472&hilit=havecore#p88472
"A simple string looks like this:
-sel:all,+sel:(ger|eng|nolang),-sel:(havecore),-sel:mvcvideo,=100:all,-50:ger,-10:forced
This selects all tracks for some languages and deselect any lossless track if a core is available, because I do not need in most cases an lossless track (no benefit and the size can be huge)."
