suddenly no disc will rip
hiacedrifter
Post by hiacedrifter »
I've used makemkv for a few weeks ripping blu-rays, faultlessly. Suddenly every disc (4 so far!) gives a "failed to open disc" error. What might have changed? Has it expired (i have uninstalled and reinstalled). Could other software be affecting it? I literally cant get a single disc to rip.
Fails so far:
Mystery road
Blade runner
Deadwood series 1
The Survivalist
Re: suddenly no disc will rip
Without more information (such as a debug log), not much can be said - LOTS of reasons disks can fail to rip. So much so that there is a "Sticky" message at the top of this forum about dealing with errors.
hiacedrifter
Hi, this is not one disc! I ripped 30 or 40 discs with no problem. Suddenly 10 discs in a row wont rip, i.e. I can no longer rip anything. Is it possible I have inadvertently changed a seeting? Could a windows update have broken something? I was messing around with VLC workarounds to get it to play blu-ray ... could that have affected it?
I'm clutching at straws, but its not possible that i just happened to pick 10 blur-ays at random that wont rip.
hiacedrifter
I just tried the backup option, and that works (not sure what it is for but I'm experimenting!), but only if I don't tick the decrypt option. I wonder if that is related?
hiacedrifter
I turned on debug logging and saw this:
DEBUG: Code 5 at I4Oa1LB|rAXT>=_}Fzo!4:121262026
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB_v49_save.tgz
For the Access Denied error, Preferences->General, set the MakeMKV data directory to somewhere that you have permission to write to. My recommendation is a directory like "C:\MakeMKVData", so you remember what's in there.
Setting up the VLC integration should NOT interfere with MakeMKV itself working.
hiacedrifter
Woodstock wrote:
Sat Jul 18, 2020 3:58 pm
Thanks, I've now sorted that issue. But now back to original issue. I've gone from every disc rips, to every disc fails. Surely something has changed?
Latest disc (Young & innocent) gives this:
DEBUG: Code 0 at A4|1O]oNyrw2.-zn:121263958
DEBUG: Code 0 at A4|1O]oNyrw2.-zn:29395172
DEBUG: Code 233 at z5VZhqDoERx08LJUnzvqHG99:0
There is important information at the start of the debug log that is often relevant. If you do not have a LibreDrive compatible disk, if you inserted a disk with too new a version of AACS, your drive could be blocked from reading ANY BD until a new version of MakeMKV is issued. That information will show up early in the log, even before you select files to rip.
hiacedrifter
Ok I've emailed over log files for one of the problem discs. I also sent over log files for the first problem disc I encountered on 6th july, but didnt hear back. By the way, is there a way to donate to patreon to support makemkv?
Email to support can take a bit of time - Mike gets to things as time permits.
The only "contributions" Mike accepts are purchases of permanent licenses, which is done through the Help->Purchase link in the program.
jinx100
Post by jinx100 »
You will get the quickest help if you copy the entire log file into a code box in you next posting here. This will get more eyes looking at your problem. As Woodstock said, there are important notes at the start of the log. Just posting one snippet seldom helps.
penguin_icecream
Post by penguin_icecream »
Apologies for reviving an old thread but this is the exact issue that I've been struggling with for several days now.
I have ripped close to 200 DVDs with MakeMKV no problem. I upgraded to 1.18.1, got 1 more rip done and then the next disc I went to rip couldn't be read. I figured, huh guess the disc is more scratched then I thought and plugged in another... only for that to fail at read. And then another... and then another. I went back and attempted some reads of discs I had already successfully read and ripped. After a 6 I turned on debug logs and tried them all again.
Debug log started at Sat Jun 21 04:00:00 2025 , written by MakeMKV v1.18.1 linux(x64-release)
001005:0000 MakeMKV v1.18.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/<usr>/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.5.0/OpenSSL/3.0.13/1.59.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at *s,+4m-r">yFd&'k/Y<sa&:29393631
No  SDF v098: hp_HLDS_DVDRW__GUD0N_SD03_20160108175500_B6ARVP4414486
SDF id v098: hp_HLDS_DVDRW__GUD0N_SD03_20160108175500_B6ARVP4414486
No auto SDF v098: hp_HLDS_DVDRW__GUD0N_SD03_20160108175500_B6ARVP4414486
DEBUG: Code 0 at lk,s^g,>rq4E|q#1p:29396253
DEBUG: Code 0 at Y:/BzUZD/;fW"z7T:213136746
001003:0020 DEBUG: Code 0 at |X'!q)-CE\{1Wk3sR:29394781
001003:0020 DEBUG: Code 0 at |X'!q)-CE\{1Wk3sR:29395241
003031:0000 Drive DVD+R-DL hp HLDS DVDRW  GUD0N SD03 B6ARVP4414486 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
001003:0020 DEBUG: Code 1140851772 at 6Zq;JD3(H$k\*}:121273020
001003:0020 DEBUG: Code 0 at 6Zq;JD3(H$k\*}:29400071
001003:0020 DEBUG: Code 24 at Zvu+tiSf NOPD`:121261727
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
001003:0020 DEBUG: Code 1 at 6Zq;JD3(H$k\*}:29400071
003042:0000 IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
001003:0020 DEBUG: Code 1 at 6Zq;JD3(H$k\*}:121262210
001003:0020 DEBUG: Code 0 at +P7x;g&QU8.W%.Q)&:121263245
001003:0020 DEBUG: Code 101019395 at Y:/BzUZD/;fW"z7T:121271617
001003:0020 DEBUG: Code 101019395 at %]@]BaG$'abhOh76:213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
DEBUG: Code 101019395 at fPU]a<H}AGNFc7Vv\w:29394896
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '38912'
001003:0020 DEBUG: Code 101019395 at fPU]a<H}AGNFc7Vv\w:213131502
001003:0020 DEBUG: Code 101019395 at 6Zq;JD3(H$k\*}:213136907
001003:0020 DEBUG: Code 2 at 6Zq;JD3(H$k\*}:213130053
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
001003:0020 DEBUG: Code 101019395 at fPU]a<H}AGNFc7Vv\w:121263429
001003:0020 DEBUG: Code 101019395 at fPU]a<H}AGNFc7Vv\w:121262302
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '49152'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL hp HLDS DVDRW  GUD0N SD03 B6ARVP4414486' at offset '49152'
001003:0020 DEBUG: Code 2 at 6Zq;JD3(H$k\*}:29400232
003042:0000 IFO file for VTS #2 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
001003:0020 DEBUG: Code 2 at 6Zq;JD3(H$k\*}:121262210
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
001003:0020 DEBUG: Code 3 at 6Zq;JD3(H$k\*}:29400071
003042:0000 IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
003002:0000 Calculated BUP offset for VTS #4 does not match one in IFO header.
001003:0020 DEBUG: Code 4 at 6Zq;JD3(H$k\*}:29400071
003042:0000 IFO file for VTS #4 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
001003:0020 DEBUG: Code 4 at 6Zq;JD3(H$k\*}:121262210
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '40960'
003002:0000 Calculated BUP offset for VTS #5 does not match one in IFO header.
001003:0020 DEBUG: Code 5 at 6Zq;JD3(H$k\*}:29400071
003042:0000 IFO file for VTS #5 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '0'
001003:0020 DEBUG: Code 20 at (K/GDE$xt*e2FF}h3b):213133480
001003:0020 DEBUG: Code 117572073 at fPU]a<H}AGNFc7Vv\w:29394459
002003:0000 Error 'Internal error - Input parameter is incorrect (489)' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '20480'
001003:0020 DEBUG: Code 117572073 at fPU]a<H}AGNFc7Vv\w:213131502
001003:0020 DEBUG: Code 117572073 at 6Zq;JD3(H$k\*}:213136907
001003:0020 DEBUG: Code 6 at 6Zq;JD3(H$k\*}:213130053
003002:0000 Calculated BUP offset for VTS #6 does not match one in IFO header.
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '49152'
001003:0020 DEBUG: Code 48 at (K/GDE$xt*e2FF}h3b):213133480
001003:0020 DEBUG: Code 117572073 at fPU]a<H}AGNFc7Vv\w:121263429
001003:0020 DEBUG: Code 117572073 at fPU]a<H}AGNFc7Vv\w:121262302
002003:0000 Error 'Internal error - Input parameter is incorrect (489)' occurred while reading 'DVD+R-DL hp HLDS DVDRW  GUD0N SD03 B6ARVP4414486' at offset '49152'
001003:0020 DEBUG: Code 6 at 6Zq;JD3(H$k\*}:29400232
003042:0000 IFO file for VTS #6 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
001003:0020 DEBUG: Code 6 at 6Zq;JD3(H$k\*}:121262210
001003:0020 DEBUG: Code 0 at +P7x;g&QU8.W%.Q)&:213131134
Launching /usr/bin/mmgplsrv
003002:0000 Calculated MVOB offset for VTS #0 does not match one in IFO header.
DEBUG: Code 0 at P/^B>Gs`5 <EV2X,;[=0:29396460
001003:0020 DEBUG: Code 233 at cJLk+aGMJoYn0Bi7y/Mx5tEe:0
001003:0020 DEBUG: Code 233 at LMGv/c1+eY6ybfe3ryM1V+G/:0
001003:0020 DEBUG: Code 233 at 91ZxbFQnHqG53MimDdkTA6Nx:0
001003:0020 DEBUG: Code 233 at b+YiwLw28UHgfSg8mUYW2dPQ:0
001003:0020 DEBUG: Code 233 at n1FGwP/nfs20Xdfdidy9PGC2:0
001003:0020 DEBUG: Code 233 at daix59xZQO0brrAIKh64k6nx:0
001003:0020 DEBUG: Code 233 at 83eeZ/urdCEaTnoThHAzkgjc:0
001003:0020 DEBUG: Code 233 at JHqTiwguuCinEydSGspxHixU:0
001003:0020 DEBUG: Code 233 at JB9t52GCz1JZPNDn65fYZ0Wd:0
001003:0020 DEBUG: Code 233 at N5pRJOix856XnJ47SFfFjt8r:0
001003:0020 DEBUG: Code 233 at yu5/qd11TlCBXNUWVaNQOReb:0
001003:0020 DEBUG: Code 233 at WqlA7Nw7juPdO+BIcBrWdoaS:0
001003:0020 DEBUG: Code 233 at vuTsbmIj9RO1Ju2BOLE9VdzH:0
001003:0020 DEBUG: Code 233 at CeZmJpGqZiYwWiF2LOv1rJhM:0
001003:0020 DEBUG: Code 233 at 1Fs3TWQvnYC0J/bPxuBqkLB0:0
001003:0020 DEBUG: Code 233 at 6v1qWscacD5jg3jf+bTxAS3n:0
001003:0020 DEBUG: Code 233 at KEGfd6P4OS8GlVpDYyeDc4u5:0
001003:0020 DEBUG: Code 233 at RitAkkgoAbHYVNeTbjSOWQ4D:0
001003:0020 DEBUG: Code 233 at 6Lh2pOfZkAhumUsynKkv0g9h:0
001003:0020 DEBUG: Code 233 at VuhNLT6Acb5xtSvQCETT6Who:0
001003:0020 DEBUG: Code 233 at hytvF2nqjb3fmuBBAOAA+e7B:0
001003:0020 DEBUG: Code 233 at bcbGDqO1PHqAsbIOGM25Bs5z:0
001003:0020 DEBUG: Code 233 at drsQRZz82lCoiQ+lg8kLaepH:0
001003:0020 DEBUG: Code 233 at ocmcArrNcqTOOFEWR5sOeBsE:0
001003:0020 DEBUG: Code 233 at 4P+0a/L804pgzWMr1p5UARID:0
001003:0020 DEBUG: Code 233 at 6WUIfOUIMaKx7BWe5pYjtAxt:0
001003:0020 DEBUG: Code 233 at 6JRalHqHYrP6J0a62HSFM5IT:0
001003:0020 DEBUG: Code 233 at KvsmzA6vGHpFBjB7AFSAUCRU:0
001003:0020 DEBUG: Code 233 at FJeQ8tLk7ZqFeOiza/quhcZz:0
001003:0020 DEBUG: Code 233 at eUvNO6n+O8E3TQ/Ue40q6tC1:0
001003:0020 DEBUG: Code 233 at daJztgXZQuJCg+nSqKQ3GnB7:0
001003:0020 DEBUG: Code 233 at Ifh3KXL/gJ+ZfrhbNzU4F1MH:0
001003:0020 DEBUG: Code 233 at oORxFpKKpJvopLI3Yt/drzJu:0
001003:0020 DEBUG: Code 233 at ql0IZJ47ApoNRCb0BDnSczRm:0
001003:0020 DEBUG: Code 233 at qVx2yvQ6nXPsOb/GWYj5EF1m:0
001003:0020 DEBUG: Code 233 at uA+yzIV2ejjl5Hh7mxv3cT15:0
001003:0020 DEBUG: Code 233 at dsfYsi58ZGtT6yO3K2HVIVi7:0
001003:0020 DEBUG: Code 233 at GSQKLivc1VlLZcSKCZetaDL4:0
001003:0020 DEBUG: Code 233 at jpLe8aArmLhDUtyVIPvAai65:0
001003:0020 DEBUG: Code 233 at ieAfj88ijw/vFhh88O9itkbC:0
001003:0020 DEBUG: Code 233 at fLY1SIoCzayP+vuUocJUg/a0:0
001003:0020 DEBUG: Code 233 at fqzf/QXxDLMuk8JiK3nNg3td:0
001003:0020 DEBUG: Code 233 at iWwNn8+I1r1pzY3jP929UEbk:0
001003:0020 DEBUG: Code 233 at +K1LrSDsx3DXKeBRAFHhFdhB:0
001003:0020 DEBUG: Code 233 at KQgLlD0npRbaK0J+wrBs5hQv:0
001003:0020 DEBUG: Code 233 at 7Sj9M9L/Skd+ZAUQtdaRoD/X:0
001003:0020 DEBUG: Code 233 at tKjDu+ELlT76gFgr8IPOgFWj:0
001003:0020 DEBUG: Code 233 at WBSCo7qQ8Dvz9MmGt4Hx1uKE:0
001003:0020 DEBUG: Code 233 at 6Q9boYpHRtbA/hobWB3H/WNI:0
001003:0020 DEBUG: Code 233 at I1ZqOShz7Odh09O7HJGwXgsl:0
001003:0020 DEBUG: Code 233 at 41pd8bIGS9vPexW09lPr3FFc:0
001003:0020 DEBUG: Code 233 at vWgFYDCh8ofl+shYceFcbI3J:0
001003:0020 DEBUG: Code 233 at SQs2NK3+kacz0ZorD4JCxuT1:0
001003:0020 DEBUG: Code 233 at r6kmgHv7egUwzgSA4LBoHNRS:0
001003:0020 DEBUG: Code 233 at WDqvbJcM/hBQAyWqUOiYK882:0
001003:0020 DEBUG: Code 233 at nMqfcjS3p+it7CkkEu4hHah9:0
001003:0020 DEBUG: Code 233 at yduWUmUak5qIJXdmPf4im6zB:0
001003:0020 DEBUG: Code 233 at lKua4BinIAP8cKsXu7WG2YwM:0
001003:0020 DEBUG: Code 233 at S3nRtj8dYFhq6+Gz5rncPnRk:0
001003:0020 DEBUG: Code 233 at bIXmz3ZLGpnURwsTzuFGkBrO:0
001003:0020 DEBUG: Code 233 at YKWSASqA/DnmY0vg5NHew0ol:0
001003:0020 DEBUG: Code 233 at Mz1HoKRBhV15XOuCbForhpd8:0
001003:0020 DEBUG: Code 233 at DdiIZNRvQb4HtIHr1wYn29m3:0
001003:0020 DEBUG: Code 233 at lq8Kw7FQ/+/ni0WUjgaf2Cf/:0
001003:0020 DEBUG: Code 233 at z9kXzvMkdEUf/WOYHOTyVzz9:0
001003:0020 DEBUG: Code 233 at 7OteJvR48bzQgl4DtjljshiT:0
001003:0020 DEBUG: Code 233 at t3xwb/C4Nef90V1wEKmHM0fE:0
001003:0020 DEBUG: Code 233 at ihx0aBsLSMXBDS+WFHMBOZEX:0
001003:0020 DEBUG: Code 233 at 1Ctx6l7UwRZsXJWzujszuor/:0
001003:0020 DEBUG: Code 233 at Agh2iuau3a8OQ8uaD4UZheSm:0
001003:0020 DEBUG: Code 233 at fs8qchmy72rXi0Y4M7lSZWd9:0
001003:0020 DEBUG: Code 233 at Fo+lUlbyOXMSFB/SLOxcP0B9:0
001003:0020 DEBUG: Code 233 at wag5UAqSUa5k/1EZ4rtS1Ms6:0
001003:0020 DEBUG: Code 233 at X+oAEHJ4MvUAL7ot0oEP2i2S:0
001003:0020 DEBUG: Code 233 at lWm5ynssiMqLzQVmj2wOzu5F:0
001003:0020 DEBUG: Code 233 at FUQY0PN/9IOk4W+bUyMCXOY7:0
001003:0020 DEBUG: Code 233 at //UfK7shJjpJGQnfD/Tc+0TU:0
001003:0020 DEBUG: Code 233 at ubgyJ6gSIDztfq30fknzDxGq:0
001003:0020 DEBUG: Code 233 at qnS9iZ9cjLcPxkmxOQKVETUo:0
001003:0020 DEBUG: Code 233 at ahZAEKM+MoHKdXEBkbZBXMko:0
001003:0020 DEBUG: Code 233 at AeEJ9cxrifVFe7YmbZI1ps2K:0
001003:0020 DEBUG: Code 233 at V2+0ua9g7tMW9s3J+PU69/gP:0
001003:0020 DEBUG: Code 233 at yCCM58uXfpuBjg/1X4VUSwO3:0
001003:0020 DEBUG: Code 233 at YJpj3vQ2t3r7JzppJ2I1VZSs:0
001003:0020 DEBUG: Code 233 at F8BBGQEUPNY5pcyaaqAD1hbU:0
001003:0020 DEBUG: Code 233 at 60/YCI/qENiUKjOIjKA/hGSl:0
001003:0020 DEBUG: Code 233 at khD14tJbv5hjXiIixEiZOUBL:0
001003:0020 DEBUG: Code 233 at Aq439MXFQGH2WxsK/QBoh8dr:0
001003:0020 DEBUG: Code 233 at /aWMszacvnTBoQj1Vdgdtss5:0
001003:0020 DEBUG: Code 233 at VQGMjvUgMYXj+fRHfHB1wKAh:0
001003:0020 DEBUG: Code 233 at C6XhBkSH1OHZr+RFDRaM+E8i:0
001003:0020 DEBUG: Code 233 at LcDsstUyxqodJhk8h5Sd0Pjy:0
001003:0020 DEBUG: Code 233 at ZXbqLkD0B6Q2r+tJtUx8kSWC:0
001003:0020 DEBUG: Code 233 at 3FInmn5WO/4s/a7gLbGY76IE:0
001003:0020 DEBUG: Code 233 at D/xujgvLhjGYc0tEUNqDgwQ3:0
001003:0020 DEBUG: Code 233 at z7G0G2Adnco1XjtSuY1pPa+s:0
001003:0020 DEBUG: Code 233 at 6qr1AEgblJKXjfzmVsPV6KKx:0
001003:0020 DEBUG: Code 233 at e32l9yKPEGJEiTv0UE0E81ny:0
001003:0020 DEBUG: Code 233 at zYi6RExk7nkIC+SQkgjMeoHs:0
001003:0020 DEBUG: Code 233 at veSDbI2OSU7489vbWzEMrjBq:0
001003:0020 DEBUG: Code 233 at iPYMFaRddhRk67yVafUxIyyr:0
001003:0020 DEBUG: Code 233 at x6WUH9ot3x3+6smCnouUpR2I:0
001003:0020 DEBUG: Code 233 at 1K+ah+VXdwApcq+S5uxQbDH4:0
001003:0020 DEBUG: Code 233 at sSEumZLugZNuUFGnBdoI1SPP:0
001003:0020 DEBUG: Code 233 at E+as0hUFDvkFOMbwioGkMgbj:0
001003:0020 DEBUG: Code 233 at yVwvKdu6w7Okz8YhTOKpSRLm:0
001003:0020 DEBUG: Code 233 at zZWhGdf7XlQlVEFbqXNRgRpu:0
001003:0020 DEBUG: Code 233 at nCTP35HinVN0rVs+w3leCQ3G:0
001003:0020 DEBUG: Code 233 at 2dePsDDuLij/bc3rZD/Nn+k5:0
001003:0020 DEBUG: Code 233 at zMmVRVZX8OnRSRhhgrWVdJqe:0
001003:0020 DEBUG: Code 233 at phV5IRGDNVDTtZdDrhghtreW:0
001003:0020 DEBUG: Code 233 at RZ3YJpRm8bSuN0S+iJAjw9H7:0
001003:0020 DEBUG: Code 233 at HxcekW4UOTu0uneyKAn/gHED:0
001003:0020 DEBUG: Code 233 at gDQ7thMGVTnzcVk4nmQM45My:0
001003:0020 DEBUG: Code 233 at WE6xXnBCc22qGvw/6u25XigM:0
001003:0020 DEBUG: Code 233 at pCRNwLY985UWIJ5a5xkmvRIZ:0
001003:0020 DEBUG: Code 233 at ycLrtnKba+UUNuXMF2glXLtZ:0
001003:0020 DEBUG: Code 233 at X1kLeDQ2lYhP+G0cWZeQ9Gtv:0
001003:0020 DEBUG: Code 233 at bo0BruZfhIws7h4MN6Iza4jS:0
001003:0020 DEBUG: Code 233 at dMLsdGAOzTExKCMVaLgwuxTM:0
001003:0020 DEBUG: Code 233 at 2Ufjf0YsppU8QnoKvKGbVp9r:0
001003:0020 DEBUG: Code 233 at OLgZ0DNBOA/4RND9lxcUUgv5:0
Application exited at Sat Jun 21 04:14:03 2025
Note that the date and time are off. I've been using the library faketime to work around the registration issues that we've been dealing with since the last beta key expired at the end of July and the registration purchase site is also down. I wanted to mention this in case that could potentially be the cause of my issues here.
GJamesB
Post by GJamesB »
This could be the issue. I got the same error with a different drive while using faketime and entering the updated beta key and ceasing using faketime resolved the issue.
However, I have since been unable to even mount a Blu-ray disc with or without MakeMKV with my drive. MakeMKV provided no information, not a single debug line. I even tried moving the drive to another Mac that has never seen MakeMKV and it still ejects without mounting the disc. Older discs that previously worked no longer work. First Blu-ray to show the problem was Doctor Who - Colin Baker - Complete Season 2 - Disc 1. Could it have been a poison disc that revoked the drive?
GJamesB
Post by GJamesB »
I now suspect it is blue laser failure. I can still mount DVDs, but Blu-rays no. (Though it no longer automatically ejects a Blu-ray.) I guess I'm buying a replacement drive.
