Title failing to save due to subtitle track?
batty
#1 Post by batty » Wed Jul 15, 2020 2:06 am
I ran into some trouble with disc 3 of Shout Factory's Gekisou Sentai Carranger with Title #3 failing to save. However, it saves just fine when I don't include the English Subtitle track.
Am I correct in assuming this is a mastering error?
MakeMKV v1.15.1 win(x64-release) started
Title #1 was added (5 cell(s), 0:19:55)
Title #2 was added (5 cell(s), 0:19:55)
Title #3 was added (5 cell(s), 0:19:56)
Title #4 was added (5 cell(s), 0:19:55)
Title #5 was added (5 cell(s), 0:19:55)
Title #6 was added (5 cell(s), 0:19:55)
Title #7 was added (1 cell(s), 0:00:11)
Saving 1 titles into directory C:/...Desktop/Etc
AV sync issue in stream 0 at 0:00:00.033 : video frame timecode differs by -467.133ms
Failed to save title 2 to file C:/...Desktop/Etc/title_t02.mkv
0 titles saved, 1 failed
Re: Title failing to save due to subtitle track?
#2 Post by Woodstock » Wed Jul 15, 2020 2:43 am
Not necessarily a mastering error; it could just be that there is a bad spot on the disk that corresponds with where that subtitle is in the file. I've had rips fail for similar crazy stuff.
It's been a season for crazy stuff - are you ripping this with a DVD drive, or a BD drive? Some BD drives do not do well with marginal DVD disks. As I mentioned elsewhere, I keep 2 USB DVD drives available for when I hit a disk like that, which happens about once a year.
batty
#3 Post by batty » Wed Jul 15, 2020 3:30 am
DVD drive. I tried it with a few different ones and they all hit this same failure. So I'm at least confident that's not the snag.
Ezatoka
#4 Post by Ezatoka » Wed Jul 15, 2020 3:35 pm
Wasn't there something about closed captions which sometimes were said they are there, but there weren't?
What happens if you deselect only forced subtitles?
Edit: thanks Woodstock *changed forced to closed captions*
#5 Post by Woodstock » Wed Jul 15, 2020 4:03 pm
I'd forgotten about that - if the DVD claims to have Closed Captioning, but doesn't actually have CC, the rip can fail. Disabling the CC track prevents the problem.
