kazuma
#2671 Post by kazuma » Tue Jul 14, 2020 6:05 pm
tr000 wrote: Tue Jul 14, 2020 10:02 am
kazuma wrote: Mon Jul 13, 2020 6:14 pm
kazuma wrote: Sun Jul 12, 2020 7:18 pm i have lyp-sync problems with profile 7 with the movie escapre from new york. whats the solution? profile 4? (LG C9 internal)
i have now used the tool of grencola and the problem is gone. but if i first demux te files and convert to mp4, i get lyp-sync issue...
You are probably demuxing the AC3 track with Atmos, which will cause audio issues. Grencola's tool converts the Atmos AC3 track into a regular AC3.
i have that already done with eac334
kazuma
#2672 Post by kazuma » Fri Jul 17, 2020 7:47 am
after i extensively tested my M9702 DV vs DV profile 7 mp4, i saw there was no difference. first i thought there was a difference but that was a placebo effect i think. now i sold my unit. it was wasted money to keep it only for DV.
Gallo73
#2673 Post by Gallo73 » Fri Jul 17, 2020 7:34 pm
Odd results with War of the Worlds MKV and Grencola's tool. I can produce the MP4, it plays on my E6 and triggers DV, but it's half the size it should be and it's obviously missing something as very stuttery. Is there something I should have done that I missed?
I've also tried MP4 muxer profile 7 (profile 4 fails to build) and , and bl_el_rpu_builder in mode 1 and 2 with TSmux4.06 and I can't get anything to work. The enhancement layer is FEL if that makes a difference.
It would be great to have a FAQ along the lines of - if your el from media info is A (MEL/FEL, max luminance or whatever parameters are important) - do B (MP4mux, Grencola or bl_el_rpu_builder+TSMux) with the associated arguments like profile/mode and program builds if it's important (like TSmux4.06 and MP464bit). Probably too complicated because of the permutations but there doesn't seem to be one method that just seems to work. I've got lucky a few times but other times it takes hours of attempts. Still feels like great progress though and it's a real achievement so far.
#2674 Post by shawnc22 » Fri Jul 17, 2020 8:00 pm
Gallo73 wrote: Fri Jul 17, 2020 7:34 pm Odd results with War of the Worlds MKV and Grencola's tool. I can produce the MP4, it plays on my E6 and triggers DV, but it's half the size it should be and it's obviously missing something as very stuttery. Is there something I should have done that I missed?
There really aren't that many different permutations as it largely depends on your playback device. For LG Internal players, demux from decrypted backup (eac3to/ffmpeg) and mux using mp4muxer. Keep the BL and EL tracks separate and use the ac3 core of the truehd audio track. For the 2019 Shield, use the newest version of makemkv or yusecope's tool to merge the BL/EL tracks and mux with tsmuxer.
If you are making mp4s for your E6, you really have no need to go near mkvs, tsmuxer (unless you're using it to demux), or yusecope's tool.
#2675 Post by RESET_9999 » Sat Jul 18, 2020 9:20 pm
So I made some color comparison tests with my HDfury Vertex on the Shield and the Sony x700 which accurately play DV.
Using the Vertex scaler, I removed the BT2020 flag from the RGB 8BIT Dolby vision signal and bingo!! the red push is gone.
No doubt in my mind this is the problem.
Shield RGB 8 BIT VERTEX FIX VS Shield RGB 8bit BT2020 DEFAULT mode
https://screenshotcomparison.com/comparison/4609
Shield RGB 8 BIT VERTEX FIX VS Sony X700RGB 8 bit DEFAULT mode
https://screenshotcomparison.com/comparison/4610
Shield RGB 8bit BT2020 DEFAULT VS Sony X700RGB 8 bit DEFAULT mode
https://screenshotcomparison.com/comparison/4611
#2676 Post by shawnc22 » Sat Jul 18, 2020 11:15 pm
RESET_9999 wrote: Sat Jul 18, 2020 9:20 pm So I made some color comparison tests with my HDfury Vertex on the Shield and the Sony x700 which accurately play DV.
Nice comparisons! have you been able to do any additional comparisons with the shield+vertex vs x700 on FEL titles?
#2677 Post by RESET_9999 » Sat Jul 18, 2020 11:29 pm
shawnc22 wrote: Sat Jul 18, 2020 11:15 pm
No, but I will now that I can get accurate colors with the Shield.
#2678 Post by shawnc22 » Sat Jul 18, 2020 11:31 pm
RESET_9999 wrote: Sat Jul 18, 2020 11:29 pm
fingers crossed for incidental FEL support on the Shield :D
Epedemic
#2679 Post by Epedemic » Mon Jul 20, 2020 9:57 am
Very nice work! BTW, do you have a chromecast ultra to try the same thing on? It also triggers BT2020 on my E6 when outputting DV.
#2680 Post by SamuriHL » Mon Jul 20, 2020 11:39 am
Maybe I missed it so apologies for being lazy and not searching right now, but what did you do on the vertex to remove the bt2020 flag? I'd like to try that with my integral 2. Thanks!!
#2681 Post by RESET_9999 » Mon Jul 20, 2020 2:10 pm
Epedemic wrote: Mon Jul 20, 2020 9:57 am Very nice work! BTW, do you have a chromecast ultra to try the same thing on? It also triggers BT2020 on my E6 when outputting DV.
No, I don't own a Chromecast Ultra.
SamuriHL wrote: Mon Jul 20, 2020 11:39 am Maybe I missed it so apologies for being lazy and not searching right now, but what did you do on the vertex to remove the bt2020 flag? I'd like to try that with my integral 2. Thanks!!
in the scaler tab, you select ''RGB FULL'' for colorspace and ''follow'' for deep color.
#2682 Post by SamuriHL » Mon Jul 20, 2020 3:20 pm
Awesome, thanks. Will try that when I get a free minute.
EDIT: Brilliant! I just tried it out on a few videos, and it seems to work. This makes the shield usable for DV until they provide a proper fix.
PapitaHD
#2683 Post by PapitaHD » Tue Jul 21, 2020 7:38 am
I’m trying to mux the movie “The Dark Tower (2017)” to profile 5, using yusesope’s tool (v4 alpha) but I’m getting errors and the result file plays with glitchy, purple and green vertical lines on M9702 and on Panasonic Oled’s internal player. I muxed it with the proper version of tsMuxeR which gives profile 5 DV, and which I’d used successfully for multiple movies.
V3, revision1 of the tool doesn’t give any errors, it finishes the process as intended but results in the same glitchy file.
The source is a full, decrypted UHD BluRay copy, and I also tried to demux the BL and EL with both FFMPEG and EAC3TO and even tried DVDFab’s single layer mp4 mode, but the end result was always the same. I have 2 different backups of the UHD BluRay, the chances are very low that both of them are corrupted.
What could be the issue? I’ve never run into this problem before.
#2684 Post by shawnc22 » Tue Jul 21, 2020 3:43 pm
PapitaHD wrote: Tue Jul 21, 2020 7:38 am Hi,
why are you making profile 5 files when you have a M9702?
PapitaHD
#2685 Post by PapitaHD » Tue Jul 21, 2020 4:10 pm
shawnc22 wrote: Tue Jul 21, 2020 3:43 pm
[/quote]
I'm making it for a friend, who has a TV which only supports profile 5.
