Alien Resurrection from anthology box
icebear8
Post by icebear8 » Tue Jul 14, 2020 12:09 am
getting this error when trying to rip the special edition of this movie (have not tried the normal movie) any run into this before? tried it 4 times with the same error, disk is in perfect condition and all the other alien movies ripped just fine.
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345579008-1345585152, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345585152, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345585152-1345591296, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345591296, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345591296-1345597440, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345597440, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345597440-1345603584, attempting to work around
The source file '/BDMV/STREAM/00759.m2ts' is corrupt or invalid at offset 1345603584, attempting to work around
The source file '<Unknown>' is corrupt or invalid at offset 2654982144, attempting to work around
Failed to save title 8 to file G:/HD Movies/Alien Resurrection/Alien Resurrection_t08.mkv
Encountered 27 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Re: Alien Resurrection from anthology box
Post by Billycar11 » Mon Jul 20, 2020 9:42 pm
Clean the disc
If it still does not work its a bad disc or drive
