Post by MartyMcNuts » Wed Jul 08, 2020 3:54 am
userr wrote: Wed Jul 08, 2020 2:52 am
MartyMcNuts wrote: Wed Jul 08, 2020 12:14 am
userr wrote: Tue Jul 07, 2020 2:12 pm
Did anyone try this method of shrinking the BL and running in through yusetool?
If you want a different DV profile, it should work. Give it a go!
Thats just it, i cant get it working.
Im running yusetool after shrinking the BL, which goes to 100% but the window remains open and i never get the "finished prompt".
When running mp4muxer after that, it never finishes for hours :/
Oh, then maybe there's something about the re-encoded file that yusecope's tool doesn't like. Can your device play profile 4? If so, then his tool is not needed.
userr
Post by userr » Wed Jul 08, 2020 4:28 am
MartyMcNuts wrote: Wed Jul 08, 2020 3:54 am
It can play profile 4 ye, 2019 shield, its needed though because otherwise its dual-layer which shield cant play?
userr
Post by userr » Thu Jul 09, 2020 1:59 pm
Grencola wrote: Fri May 15, 2020 3:27 am It's already happened :P the Ugoos AM6 Plus plays profile 7 dv rips in kodi 18.6 (seek to 5:15ish): https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view I've also heard from people who have successfully played DV profile 5 rips in kodi 19 on their shield. both devices are quickly shaping up to be m9702 killers..
thetoad wrote: Fri May 15, 2020 7:10 am if kodi can play a profile 7 dolby vision, there's no reason it wont be able to play with menus, at least if it on a device that can run java. In this case, as an android device, it isn't a likely target (though I've been off and on investigating how to run a jvm on android for kodi to use). With that said, menus for UHDs are mostly pointless, as the vast majority of UHDs are movie only punting all the extras to the regular bluray disk (there are exceptions, but they prove the rule)
What was the conclusion of Ugoos AM6 Plus concerning DV playback?
And is there a thread or information about wether kodi19 is gonna support more then profile 5?
deadchip12
Post by deadchip12 » Fri Jul 10, 2020 10:57 am
Sigh why doesn't dolby just release their own media player on pc that supports dolby vision and dolby atmos? They already got some form of that in their dolby access app, but that thing only plays some demo instead of any video files.
Gallo73
Post by Gallo73 » Sat Jul 11, 2020 7:53 pm
It's my first go today at doing this - I've made the MP4 but it isn't recognised by my LG E6 OLED when trying to play with a USB drive into the USB3 port. It looks like it tries to load (disk access light is flashing) but I just get the LG loading symbol and after a few minutes the error 'file cannot be played'. On the Shield TV it plays but as HDR which is normal I guess for profile 7.
I'd really just like a way to get DV playback from UHDs on my Shield TV ideally, but as I understand that's not possible with dual stream MP4 .If anything has changed I'd love to know. I've read through the threads but there is a lot of information and easy to miss developments.
I used the following command for mp4muxer - have I done something wrong? Does the version of tsMuxer matter to get the files from the BDMV backup I made in MakeMKV?
mp4muxer --dv-profile 7 --input-file base.hevc --input-file dv.hevc --input-file audio.ac3 --media-lang eng --output-file thematrix.mp4
Mediainfo reports the file structure correct I think:
Complete name : thematrix.mp4
Video #1
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 2 h 16 min
Bit rate : 48.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Bit rate : 66.2 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
planet_hoarder
Post by planet_hoarder » Sat Jul 11, 2020 9:25 pm
userr wrote: Thu Jul 09, 2020 1:59 pm
can Ugoos AM6 Plus playback lossless audio as well?
planet_hoarder
Post by planet_hoarder » Sat Jul 11, 2020 9:28 pm
deadchip12 wrote: Fri Jul 10, 2020 10:57 am Sigh why doesn't dolby just release their own media player on pc that supports dolby vision and dolby atmos? They already got some form of that in their dolby access app, but that thing only plays some demo instead of any video files.
because "pirates" and widows' implementation of HDR is abbysmal - which means app should be started with HDR on, in YCrCb4:2:0 (since movies use this) and display must support Dolby Vision
planet_hoarder
Post by planet_hoarder » Sat Jul 11, 2020 9:45 pm
Gallo73 wrote: Sat Jul 11, 2020 7:53 pm It's my first go today at doing this - I've made the MP4 but it isn't recognised by my LG E6 OLED when trying to play with a USB drive into the USB3 port. It looks like it tries to load (disk access light is flashing) but I just get the LG loading symbol and after a few minutes the error 'file cannot be played'. On the Shield TV it plays but as HDR which is normal I guess for profile 7.
Video #1
Format : HEVC
Codec ID : hev1
Video #2
Format : HEVC
Codec ID : hev1
Audio
Format : AC-3
Codec ID : ac-3
try to use older version of mp4muxer:
https://github.com/DolbyLaboratories/dl ... 0d7ca4eabd
in bin folder use mp4muxer_64bits.exe
it works on my LG OLED
Post by MartyMcNuts » Sat Jul 11, 2020 11:26 pm
Video #1
Format : HEVC
Codec ID : hev1
Video #2
Format : HEVC
Codec ID : hev1
Audio
Format : AC-3
Codec ID : ac-3
1. I'm not 100% certain about this but to play directly on your LG TV you should use DV profile 4 (not 7).
2. For the shield, why not use MakeMKV to create a DV mkv file (from your backup folder), then use tsmuxer to create a ts file using the video from the mkv and the audio from the mpls in the backup folder?
Gallo73
Post by Gallo73 » Sat Jul 11, 2020 11:41 pm
Thank you very much, worked first time using the mp4muxer_64bits version.
I was also able to get Dolby Vision to trigger by using yusesope's bl_el_rpu_builder with the two hevc files from the BDMV backup and remuxing the resulting single file with the ac3 audio in tsMuxer to a ts file.
Both the MP4 and the ts file trigger Dolby Vision when played on my LG E6 OLED via USB. Both revert to vanilla HDR on my ShieldTV.
Post by shawnc22 » Sun Jul 12, 2020 12:42 am
profile 7 is the right one to use when using mp4muxer for playback on the lg internal player
Gallo73
Post by Gallo73 » Sun Jul 12, 2020 8:15 am
Thanks for everyone's help. I wasted a bit of time as I thought my Shield TV 2017 supported DV playback and it does not. But I can get DV playback on my LG E6 OLED from both the bl_el_rpu_builder and mp4muxer_64bits outputs via my plex server using the WebOS plex app.
After spending a day trying to get it to work I think using yusesope's bl_el_rpu_builder is the easiest method. Here's my workflow for use on a Plex server with the WebOS plex app and an LG E6 Oled.
1. Backup disc with MakeMKV
2. Open BDMV/STREAM with TSmuxer and demux the two hevc streams (base and el) and the ac3 audio stream
3. Use bl_el_rpu_builder to combine the two hevc streams
4. Load the combined stream and the audio stream into TSmuxer and mux to ts
5. Put ts file in your Plex library and enjoy glorious DV.
userr
Post by userr » Sun Jul 12, 2020 1:36 pm
yusesope wrote: Sun May 24, 2020 12:36 pm ...
Hello, i quoted you on a random post to "ping you", i was wondering, can you see a reason why i cannot encode/shrink the BL only and then try to use -mode2 with your tool? It goes to 100% but i get no prompt like "enter to finish", and when i later try to mp4muxer it all together, it just stands there for hours.
Abit niche scenario, just wondered if you have an idea.
Cheers for amazing work
yusesope
Post by yusesope » Sun Jul 12, 2020 2:14 pm
userr wrote: Sun Jul 12, 2020 1:36 pm
Hi, are you using the 0.0.4 ALFA version of my program?
If not, you can download it from my original post (HERE).
I also invite you to read "Instructions and considerations".
kazuma
Post by kazuma » Sun Jul 12, 2020 7:18 pm
i have lyp-sync problems with profile 7 with the movie escapre from new york. whats the solution? profile 4? (LG C9 internal)
